Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
The vacuum cond is staying on and my temp is 60
Posted by John Shelton on
Anonymous
    New Friend:
  • 3 Answers
If you vacuumed and nothing has ever been replaced, the solution might be to have a tech remove freon and replace with new freon, if you call someone do not pay to have condenser coil replaced, it will work but is not necessary and time consuming not to mention costly. If you live in NYC call us at 7187302240.
Posted on Feb 19, 2011
2007 pontiac g6 3.5 temp gauge and air conditioner stopped at same time
Inspect the fuse panel located in the side of the dash that is accessible when you open the door. I think that it is a 25 amp fuse but am not familiar with the G6
Jul 28, 2016 | 2007 Pontiac G6
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/[email protected] temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
Heating Model 44360
you should have a 'hold temp' option on your remote, it should then stay at the set temp until you change it
Mar 01, 2014 | Hunter 30124 Air Conditioner
Cannot change temperature on heat & air
Temp is controlled by an electric motor(or could be vacuum hose) on the blender door of heater housing. If you find this is operating correctly, then the problem is a plugged heater core.Backflush it by removing both heater hoses and flushing from water pump side toward thermostat side.don-ohio
Oct 23, 2011 | 2000 Mercury Grand Marquis
Cannot adjust temperature on the heat & air, 2000 grand marquis, cannot get any heat, air cond temperature cannot be adjusted, it stays on cold at all times
Is this an automatic temp. control or manual heater control? if it's automatic control,it can be an expensive circuit board which has gone bad. don-ohio
Oct 22, 2011 | 2000 Mercury Grand Marquis
When I press the control to get the air temp down to 60 it goes back to 86 right away , How can I fix it ? I have a Haire portablr air cond 7000 btu model hprbo7xc7
most air conditioning unit have a built in thermometer so that it will tell you the room temp,if you set the temp and then it goes to a high number let the system rum for a while and see if the temp starts to go down in the room it is probably working fine.
Jul 21, 2011 | Haier Heating & Cooling
1989 int. cutlass supreme-2.8lt- heater not blowing any hot air, fan works fine,def.,mid level, upper, lower functions work just fine when buttons pushed. When I turn the temp. control down to 60 the...
Your closing in. There is a motor that will open the heater core venting to allow it to blow into the car. Get a heater core install picture from your auto parts dealer or car dealer for specs of where and how it is driven.
Apr 17, 2011 | 1989 Oldsmobile Cutlass Supreme
The refrigerator part is 60 degrees and the freezer part is blow 20 degrees, I found the cond fan motor locked up not running, I have cleaned the condenser coils, replaced the cond fan motor but the...
Please follow these steps.
Keep temp setting at 5 degree. Check defrost timer, thermostat and frost heater are working properly. Call repairman to check above all. Thanks.
Feb 02, 2011 | Admiral 26 cu. ft. Side-By-Side...
Reset Heating/ AIr cond temp display as well as EXT temp ????
the temp display can be switched between celsius and farenheit readings, since the car is from europe the default is celsius, The manual has instructions on changing back, You have to hold 2 buttons on the display per the manual.
May 07, 2009 | 2003 Land Rover Discovery
No heat
1st I would check any safety switches it may have such as oil drain valve switch controlled by the oil drain valve. If it has an exhaust blower, it may have to get up to a certain speed before the flame will come on. This would be a vacuum type switch. If it has a pilot light that burns all the time, it probably has a thermocouple which the pilot light heeps hot. This could also be the problem and need replaced. If there is no resturant equipment service tech in your area, A air cond tech would be your best bet for troubleshooting it. Good luck.
Feb 08, 2007 | Pitco Frialator 35CD Deep Fryer
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
Top Sub-Zero Refrigerators Experts
Dan Webster
Dan Webster
john h
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
