Question about RCA 25414RE3 Corded Phone
Hi, the ringer on my RCA telephone model 25204 has turned off, and I can't figure out how to turn it back on, despite going through the manual and trying menu options on the phone itself. Thanks for your assistance!
Posted by ipcounsel on
  • ipcounsel Feb 08, 2011
    This phone model doesn't have the "OFF" option when scrolling through the ringer tones (and only has 2 lines). Nonetheless, while trying to fix this myself I luckily hit some combination of keys that activated the ringer, so don't need further assistance. Thanks.
    No, but I fixed the problem myself.
Reparatii PC - Service IT
  • 2,574 Answers
How set your phone's ringer Tone!
1. Press the MENU button while in standby mode.
2. Use the button to scroll to SET PHONE OPTIONS.
3. Press the SELECT/SAVE button.
4. Use the button to scroll to SET RING TONE.
5. Press the SELECT/SAVE button. The ringer tone settings for each of the four telephone lines show in the display.
6. Use the button to scroll to through each ringer tone for LINE 1. A sample ringer tone is generated when you scroll to
individual ringer tones. Choose from eight different tones, or turn the ringer OFF.
NOTE: If you select OFF, the cursor automatically moves to the CID ON/OFF option. Use the button to select CID ON or OFF. (ON allows the unit to detect
and display CID records for the corresponding telephone line. OFF disables the function for the corresponding telephone.) Press the SELECT/SAVE button.
7. Press the SELECT/SAVE button to save. The cursor automatically moves to LINE 2.
8. Repeat steps 6 and 7 for each telephone line. After you select the ringer tone for LINE 4, press the EXIT button.
NOTE: The line indicators flash for incoming calls even if the ringer is disabled.
Posted on Feb 08, 2011
We have 4 RCA 25425 phones in our office. When someone calls, all phones ring. We only want main line to ring.
Page 15 of the manual shows how to turn individual phone ringers off using the "Ringer tone" setting option. RCA 25425RE1 User Manual Page 15 Hope this helps
Jan 10, 2014 | RCA 25425 / 25425RE1 4 Line Corded...
How do I turn the ringer back on on the Uniden dect 6.0
The procedure varies from phone to phone. Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Jul 06, 2012 | Uniden DECT 6.0 Cordless Phone ID
Ringer is not on
The procedure to turn on/off the ringer varies from model to model. Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
May 19, 2012 | Uniden DECT 6.0 Cordless Telephone...
Accidently turned off ringer???? how do i turn back on
Since you declined to specify the model of your RCA ViSYS 2-line phone, I can only suggest that you select it from this page to download a copy of the manual.
Feb 06, 2012 | RCA ViSYS 2-Line Speakerphone
How do I turn off the ringer on my AT&T 832 telephone? I do not see a ringer button and I do not have a manual. The phone is about 12 years old.
Hi
You can turn off the ringer completely so it no longer makes an audible sound when the phone receives an incoming call. The phone's ringer options can be accessed in the handset's menu.
Press the "Menu" button on the phone.
Press the up or down arrows until the phone's display says "Ringer Volume."
Press the "Select" button on the phone.
Press the up or down arrows until the phone's display says "OFF."
Press the "Select" button to save your settings.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 14, 2011 | Cell Phones
I somehow turned off the ringer and can't figure out how to turn it back on. I can't find my manual at the moment. Is there an easy way to both turn the ringer on and to turn it off?
Most modern phones have 2 buttons for volume control. This typically will change ringer volume (including vibrate / mute).
If that doesn't work, post your model number and we can give more exact answers.
Mar 17, 2011 | Cell Phones
My ringer is turned off?? How do I turn it back on? Uniden
This link will take you to a site that has a variety of Uniden manuals. Look for the model number in the list, to download you will need a valid email address. http://www.retrevo.com/samples/Uniden-Telephone-manuals.html
Dec 12, 2010 | Uniden Cordless Phone
Rca phone model 25204 - ringer off - how do I turn it on
Ya, I can find no way to get the ringer on, even if I reset to default settings. What the heck?!
Mar 18, 2009 | RCA 25414RE3 Corded Phone
RCA Model 25204 2 line speakerphone corded with call waiting caller ID
As bsmither said, how voice mail is accessed is very dependent on your phone company and how they've set things up. They would be the best place to ask about any problems you're having there.
As for programming the voice mail buttons on the 25204, I was confused by that one as well until I finally figured it out. Specializations aside, they're just speed dial buttons, and are programmed in exactly the same way as the ones along the right side of the phone. RCA could have documented that detail better than they did.
In my case, with Vonage, I just programmed the buttons with the numbers for the lines that they're associated with. When they dial and I'm connected to the voice mail system, I'm prompted for my VM password, which I then enter manually.
Jan 30, 2008 | RCA 25414RE3 Corded Phone
Lands Phones Logo
Top RCA Lands Phones Experts
k24674
rostit
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
