Question about Brother SX-4000 Typewriter
The printwheel is not printing the correct letter.
Posted by gardensj on
Dick O Reilly
  • Brother Master
  • 3,594 Answers
If you are not in KBII or a language mode the printwheel homing pawl is probably broken. You need a tech.
DickyO
Posted on Feb 16, 2011
Hi. My brother ax425 is printing mad. How can I correct it
First check the printwheel. look at the spokes if they are not all the same in a row, replace the printwheel. and try it.
Jul 29, 2014 | Brother AX-425 Typewriter
How do I delete all formatting?
Your problem is the printwheel. The "u" is probably broken. The lines that you see are the print hammer hitting the page instead of the character. All of the letters are on the printwheel and they are on the ends of little fingers. The tips sometimes either get bent but they usually break. Replacing the printwheel should resolve your problem.
Apr 28, 2014 | Lexmark Office Equipment & Supplies
When I push the letter "G" , for example, a
If the printwheel isn't distorted or you aren't in KBII or a language mode the printwheel homing pawl is likely broken. You need a tech.
DickyO
Sep 01, 2011 | Brother GX-6750 Typewriter
When typing wrong letters and numbers type
You might have a "proportional space" printwheel but the pitch selector is on 10, 12, or 15 instead of PS. OR it is on PS but you have a normal print wheel. Try selecting different pitches. Another thing that causes that problem is sometimes the ribbon or correction tape gets caught in the printwheel.
Feb 18, 2010 | Swintec 7040 Typewriter
The flywheel from my brother ml300 typwriter came off and i don't know how to put it back on
I assume by "flywheel", you are referring to the "printwheel" which is removable from the typewriter by unlatching the print hammer mechanism by pulling the black lever on the right side of the print hammer towards the front of the machine. To install the printwheel, drop the printwheel in its cartridge with the letters facing the paper, then push the print hammer assembly towards the paper to the latched position. Turn on machine, and the printwheel will spin and "home". If printwheel homing is not correct, repeat above procedure with slightly more pressure when latching the printwheel. (The printwheel must latch on to its drive spindle securely). Good Luck
Nov 25, 2009 | Brother ML-300 Typewriter
What do I do when I strike one letter and another is printed?
First make sure that the the pitch selector on the keyboard is set to the correct pitch for the printwheel , if there is a pitch selector on this typewriter. Also try taking out and reinstalling the printwheel then turn the typewriter off and back on so it can rehome the printwheel.
Mar 12, 2009 | Brother GX-6750 Typewriter
Typing the same letters
check to see if anything is interfering with the free rotation of the printwheel, ribbon or corr. tape if improperly installed may do this. with the mach. OFF move the printwheel by hand. if it moves ok, and it still won't print wright, you will need a repair shop to fix this problem.
Nov 23, 2008 | Brother GX-6750 Typewriter
AE-710 Letter Keys Do Not Work
Check the pitch selector switch if it is in PS this will cause this problem.
DickyO
Oct 29, 2008 | Nakajima AE-710 Typewriter
Some uppercase letters are not printing correctly
make sure ribbon and corr. tape are in properly and not interfering with the free movement of the printwheel. ribbon and tape should be between the two metal fingers and the cardholder. make sure the two fingers are not bent down into the printwheel. check the "fingers" on the printwheel to make sure they are straight. with the printwheel out of the machine, push the printhammer forward and release it to make sure it snaps back freely. if these seem to be okay then it could be a problem with the p/w motor or motherboard, and would need professional help.
Oct 09, 2008 | Brother ML-100 Typewriter
Brother SX-4000 Typewriter Logo
Norman  J Weimar Jr
Norman J Weimar Jr
k24674
