Question about Radio Communications
Hooked up cb, blows fuse when the mic is keyed
Posted by djusticejr on
Ernest Taylor
    Scholar:
  • 67 Answers
When mic is pressed transmitter is engaged. First is the Fuse the proper fuse? Could be an antenna-coax problem. Get a dummy load and hook up to your CB and try it again. If it doesn't blow the fuse, the problem is indeed in your coax antenna system. another way to test your antenna coax is to disconnect it from the radio, take a multimeter, set it to ohms 200 ohm scale, put one lead on the center pin of the coax and the other on the outside of the connector on the coax.if it shows anything at all, you have a short and that will not work. It needs to not read anything. To be sure the antenna system is ok other than swr you can also check the coax an antenna for continuity. one lead of meter on the coax center pin then other on the antenna. should get a reading, a low value. again on the outside of the coax at the connector and at the antenna side on the outside of the coax connector. should be a low reading. but you cannot have a reading from the center of the coax to the outside of the coax. disconnect the coax at the antenna and measure from center to outside at the coax if the previous reading showed a value.If you see a value on the meter, any value, your coax has a short. not good. most likely at the coax connector. redo the connector. It is possible that the coax got compromised somehow and got smashed to the point the outside coax meets the inside and touches.
Now the other possibily your fuse blows, kis because the final output transistor is bad. So if you hook up a dummy load to your radio and the fuse still blows, then the final transistor is bad. This is probably due to a bad coax-antenna system. So before you replace any parts check the coax-antenna system first or you will have the same problem and burn out another transistor in the final. If none of this helps then just get another radio or have a god buddy look at it that knows about radios. Trade him another radio or something to fix it.
Posted on Feb 08, 2011
Inline fuse blows when mic is keyed and talking
either wrong size fuse or wires are touching inside mike when keyed
Sep 09, 2013 | Radio Shack Radio Communications
I installed a connex 3300.cb.when i key the mic it blows a in line fuse.whats wroung.its new out of box
1. your unit is defective 2. If under warranty replace asap before your blamed for the damages 3. If the company refuses to take it back for an exchange, contact bbb.org and file a complaint
Jan 29, 2011 | Connex 3300 240-Channels Base CB Radio
I have a TRC 458 cb.... it keeps blowing fuses
It may have been reversed polarity on turn on. This can short out the polarity diode and then cause fuses to blow. This is a protection circuit so do not keep trying new fuses as the reverse surge can go into the radio deeper and damage it beyond repair.
Feb 02, 2010 | Radio Shack Radio Communications
Uniden PC66a CB blows fuses upon installation
yes the problem is a diode on the input of the rig. this is black with a silver band at one end it will need replacing as it has shorted out.
Aug 05, 2009 | Radio Communications
Blowing fuse
Your polarity protection diode has been blown. If you tried hooking up your CB and accidentally pushed the plug in backwards. Inside the radio, there are 2 big black diodes near the transformers, D8 and D23. Replace these with the same or bigger. You can the burnt one out and the radio will work, but if you hook it up wrong again, it will fry the radio.
May 02, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Fuse blows when I key the microphone. Why does this happen?
i am pretty sure something came loose or a connection went bad, now something is shorting, possibly to the chassis. if you think you know how to open it up and work on it than do it. Or take it to a tech and have them look at it. it should be a real quick, real simple fix.
Dec 04, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Gen lee blowing fuses when keying
What size fuse are you using? If you have a different power cord than that which came with the radio, such as one from a regular cb radio like a cobra 29, it will only have a 2.5a to 3a fuse, which will blow everytime you key up, since it is pulling to many amps. You need to have at least a 7.5a to 10a fuse. I use 7.5 amp fuses, because I have a 100 count box, and have no problems. The Stryker radio I have in front of me has a 10a fuse in its power cord from the factory, though the cord on my bench only has a 7.5a and has not blown.
If your radio still blows fuses after this, please let me know. You can message me here or email me at [email protected].
Dean Pitts
Rollin CBs
Aug 29, 2008 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
