Strip cover and check that all the dirt etc is cleaned out and the brake band is in the correct position If the brake band looks worn ie thin in places replace with new one. Dirt can also get in the pivot of the chain brake handle and cause it to jam, saw should be stripped and cleaned at the end of every days use and the bar turned over to even out the wear
Homelite chainsaw 45cc during a trade. I ran across this on another forum. If your clutch brake stay too taught when in the disengaged (run) position follow these instructions and you'll be good to go with the brake on when stop position (pushed forward) and off when in run (pulled back) position.
1. remove top cover(spark plug/ motor cover)
2. remove brake handle(1 E-clip/pin,1 screw and pivot assem.)
3. take the brake band off of the lever assem.(1 star head screw)
4. remove gold spring(was gold in mine)and cut it with a dremal or something at the( 2 1/2 -3rd worked for me) down from the start of spring.
5. replace spring cut side down in the hole. put everything back and make sure to leave the top cover screw(1 above choke) loose or choke will be very difficult to use.
