Question about Emmaljunga Viking Plus Stroller
Desparate to find the two knobs that control the stroller hood attachment and angles that I lost in a move. I bought my buggy/stroller combo emmulunga new in 1989 in the US. WHERE oh WHERE can I find replacement knobs? They were white plastic, but I would take anything that works, and would pay well to get up and running for my grandchildren. Thanks!
Posted by anamosk on
Randy Hobbs
    New Friend:
  • 5 Answers
If you can't find the knobs anywhere then you may need to make your own. This can be achieved by cutting 2 circles out of wood or metal and drilling a hole in the middle to place a screw in to fab a knob. You can do this I have faith in you.
Posted on Oct 02, 2017
When in 'swivel' mode front wheel turns wildly making it difficult to control and even stops the buggy when the wheel 'stick' at right angles to the buggy
In normal use, the front wheel needs to swivel freely - then this stroller's drive is easy and manageable with one hand (we know from extensive use with 2 kids and shopping on board).
The front wheel normally can not collide with the car. If the wheel assembly / lock is not correctly inserted, it can lock / unlock uncontrolled: try to disengage and mount the front wheel unit again.
Unsufficient tire pressure can also detoriate the drive.
Dec 20, 2015 | Regal Lager Phil & Teds Sport Buggy Double...
I need to remove the hood to replace the bolt on the side
The hood is attached with 2 screws 1 either side near the hood knobs. Then pull the hood backwards.
Aug 01, 2011 | Silver Cross Balmoral Pram Carriage...
Hi there I was wondering where to purchase the straps to the mountain buggy as these were lost while moving, thanx
I have found Mountain Buggy to be one of the best stroller companies for after sales service. Check them out. www.mountainbuggy.com/support.htm
Nov 18, 2010 | Baby Gear
I have a grey Maclaren Techno XT umbrella stroller. Plastic rainprotection was included when we bought it. Can't figure out how to put it on though, and we don't have the maunal anymore. Can anyone help us...
hi have you figured this out?
if not here goes
open up raincover there should be a flap towards the top this just hooks on the front of the hood and should have 1 hole either side which pop over stud on the hood the rest of the cover will fall to footrest of buggy where it will attatch to the frame at the bottom.
here is a picture with it fitted to the buggy
http://baby2travel.co.uk/Maclaren_RC_Techno.html
Oct 16, 2010 | Maclaren Techno XT Umbrella Stroller
Cant get wheel on - Mountain Buggy Urban Elite
I believe this company http://www.outnabout.co.uk/ might be able to help, they sell parts to Mountain Buggy's and other strollers.
Apr 05, 2010 | Mountain Buggy Urban Single Stroller
Hi I am trying to remove the handle on my phil
Put a screwdriver into the screw on the one side & hold the little grey attachement on the other, its only possible if you remove the seat and hood attachement first. Pull them over it so they are free from the little grey attachment. Hope this makes some sense...
Jan 25, 2010 | Regal Lager Phil & Teds Sport Buggy Double...
Have you managed to fit the carrycot already
If this is the same as the UK model then you should make sure that you remove the hood of the pram (not the carrycot hood) as this makes life so much easier. You could contact www.mountainbuggy.com so that they can send you a manual.
When you attach the carrycot, there should be a clip either side of this to attach to the chassis, these clips snap shut when aligned correctly with the chassis.
I hope this helps.
Sep 14, 2009 | Mountain Buggy Urban Single Stroller
From pram to buggy...
there are studs up the top of he seat and alond the back of the hood, they stud in to each other, with this the fabric folds down
Jan 08, 2008 | Silver Cross Sleepover Classic Stroller
Baby Gear Logo
Top Emmaljunga Baby Gear Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you an Emmaljunga Baby Gear Expert? Answer questions, earn points and help others
