If you power the machine off and on and it comes back, try replacing the whole transfer belt unit. If it still comes back, sorry dude you're out of luck. Your copier can't swing the hinged portion of the transfer belt on and off your color drums because a badly designed gearshaft for your transfer lift motor has worn out and probably ate up a bearing or bushing as well. This is a known problem and Sharp has published a service bulletin addressing this. It may be motor rebuild time for you, with the new edition gearshaft.
how do i clear an L1-00 error on sharp mx-b402
