Apple iMac G5 Desktop Logo
Posted on Feb 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Finder - question mark alternating flashing at start up
Anonymous
Level 2:
Scholar:
  • Expert 109 Answers
  • Posted on Mar 01, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
109
Questions
0
Helped
19867
Points
138
P.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial; min-height: 15.0px}
The flashing question mark indicates that there is a problem with the operating system or hard drive. Try to boot from the Mac OS X install disc by holding down "C" on the keyboard at startup.
If the computer boots normally from the Mac OS X install disc. Go to the Disk Utility from the disc. try to Repair Permissions on the hard drive. If after a while it seemed to work then is it time to reinstall the operating system. If it fails to repair permissions and gives you a bunch of red errors its time to replace the hard drive.
What's wrong? My Lowrance Mark 5x dsi depth finder flashes or pulsates a depth of 60 ft. All the time.
Since the unit powers up, we can pretty much eliminate a power supply problem.
I would start by carefully inspecting your transducer lead for kinks, crushing etc. Assuming the cable is OK, clean and lubricate (silicone spray, safe for plastics) the cable end and where the cable connects to the unit.
Hope this is helpful to you.
-Steve
1helpful
How to use a stud finder
The stud finder works by picking up density of the product it is pressed and slid on..Turn your stud finder on make sure the ok light is on...then slightly press it against the wall or surface you are working with,,then slowly moved it right or left still against the surface. As the finder starts to detect more density "thickness" it will. Glow or beep depending what type you have..It will get brighter,louder or what ever it signals are while crossing the stud beneath the surface..keep moving until it stops then move back
again until it stops.....mark or note the position where the signal starts then find the middle...2x4's are 1 1/2 inches across...so center should be 3/4 of an inch...good luck..
Ibook g4 won't open just gets a flashing equation mark and the finder icon
Sorry, either your hard drive cable is loose or your hard drive has died.
When i turn on my ibook A1133 a folder flashes with the finder icon then a ? question mark and is unresponsive to the keyboard or trackpad
click start control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
hope this helps
1helpful
THE CAR BATTERY FLASHED WHEN I WAS DRIVING.THE CAR THEN STOPPED AND COULD NOT START -RADIO WAS OFF. A RED EXCLAMATION MARK APPEARS ON THE DASHBOARD
SOUND LIKE FAULTY ALTERNATOR. BUT CHECK ALTERNATOR DRIVE BELT AND FUSE AND WIRE CONNECTIONS FOR LOOSENESS AND DAMAGE. TURN OFF RADIO BEFORE DISCONNECTING BATTERY NEGATIVE CABLE TO KEEP FROM LOCKING OUT RADIO.CHECK ALTERNATOR OUT PUT AT BATTERY SHOULD BE 13.5 TO 14.5 VOLTS. IF NOT ALTERNATOR IS FAULTY.
1helpful
Skil 2100daf angle finder
I was trying to reset the zero on my angle finder. It's a Powerfist Digital Angle Finder, the same as the Skil 2100.
After turning the unit on, if I press the Miter and Hold button together and hold them, the unit goes into 'calibration' mode. (The display flashes 0.0). If you do nothing, it will always stay in this mode forever after that.
You can then reset your unit - it takes time however and patience.
With the aid of a large protractor, draw angles on a large sheet of paper (I used a couple of 11 X 17" pages) from 0 degrees all the way up to 220 degrees.
Turn on your angle finder and make sure the numbers are flashing 0.0. This will be your 0 degree reading. Hold the finder closed and press the Hold button once.
The display will now read 10 degrees. Open up the finder until it matches your 10 degree marks on your paper and press the Hold button again.
The display will now read 20 degrees. Open up the finder until it matches your 20 degree marks and press the Hold button again.
Continue setting your angles in this fashion up 'til you reach 220 degrees. The next button press will close the calibration cycle and the numbers will stop flashing.
Your unit is re-calibrated. Now, if it's off - you've only yourself to blame.
2answers
Grey screen folder icon flashing and alternating with ?
The computer can't find an operating system. Start up from the OSX disc and check the drive with 'Disk Utility'. The system may have got damaged, or the drive may need to be repaired. Run 'First Aid'.
Camera will not turn on. As I rotate the selector switch the light flashes at each position. Even when I switch it to off the off light flashes on and off. The screen stays on but it is blank.
Hello, Did you try pressing the little silver button marked "EVP/LCD" it is located at the left of the view finder,This turns the screen on and off.
Hope this takes care of problem.
Best Regards, Russell
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
