Question about Canon PowerShot A520 Digital Camera
This camera was working fine, was turned off, and then a day later wouldn't work. The LCD screen on back works only if the Mode Switch is in the review mode (or DOWN), and does not light up under the picture taking mode (or UP) position. Also, while the switch is in the UP position, the ON/OFF power indicator button no longer stays lit. It does, however, stay lit in the Mode Switch in the DOWN position. First problem in three years. Nice little camera.
Posted by pisces976 on
andrias
    Master:
  • Canon Master
  • 443 Answers
You may need to take it in to get it serviced or ntry out thees sights on the web
http://software.canon-europe.com/
http://www.givemefile.net/drivers/digital_foto/canon/powershot_a520.html
Posted on Dec 25, 2011
Rear lcd screen black in shooting mode but works fine in playback
Solved the problem by going to the Canon product support site. It seems that there is no problem at all. The way the camera is designed is the problem. To be able to use the rear display lcd as a view finder, the camera needs to be able to lift the mirror to allow the sensors to pick up the image and display it on the screen. The 20D does not have this abilitiy. Apparently some later models do allow you to raise the mirror. It was this feature on those models that led me to believe that the 20D should do this too.
Jan 25, 2010 | Canon EOS-20D Body only Digital Camera
I switch the canon Ixus 60 on in camera mode and the LCD screen is blank. THe LCD screen works fine in video and review mode.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Jan 17, 2010 | Canon Cameras
My cannon power shot sd600 viewer doesnt turn on
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD screen on and off to save batteries. You would then use the optical viewfinder in its place. Try pressing this button one more time to see if it turns back on.
Oct 13, 2009 | Canon PowerShot SD600 Digital Camera
Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
Jul 07, 2009 | Canon PowerShot SD600 Digital Camera
LCD Screen not working, but camera still takes pictures
Looks like the contacts of the LCD of your camera are loose. Be advised that this repair would require you to take it apart and may vvoid your warranty. If there are no faulty contacts then you will have to replace the LCD screen. Should cost you around 100-150$
Nov 14, 2008 | Canon PowerShot A640 Digital Camera
Viewfinder not coming on!
I found this "solution" on another site and it actually worked!
Turn the camera upside down. Now, with the device off, tap it a few times in your hand. Now, turn the device on in the viewfinder mode. Tap it again if the viewfinder isn't active.
Jan 22, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Digital camera wont turn on
I just answered another question similar. Try that.
http://www.fixya.com/support/t244396-wont_turn
If it HelpsYa, please choose FixYa! ThankYa! =)
Nov 30, 2007 | Fuji FinePix A360 Digital Camera
Not switching on
sound like a bad back light or bad lcd. replace it and you should be fine . I fix camera's also.
Nov 28, 2007 | Casio Exilim EX-S500 Digital Camera
Switches off when try to take pics
i came to know the reason why this happens. the CCD is damaged. It will take around Rs2000 to repair the cam if you are in India.
Apr 18, 2007 | Fuji FinePix F401 Digital Camera
Fuji f700
I recently had trouble with the LCD Display coming up with a black screen. So I mailed it to Fuji with a letter explaining the problem. About 3 weeks later I got it back in the mail and it seem to be working fine until a month later. I turned it on and the LCD display show a black screen only now it has white lines. I'm so incredible mad and extremely dissapointed in Fuji. Reading online I have notice many people having trouble with Fuji Products. I WILL NEVER BUY a Fuji again!!!
Jan 15, 2007 | Fuji FinePix F700 Digital Camera
Canon PowerShot A520 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
