Question about Toshiba 62HM95 62" HDTV
My TV seems to making a terrible rattling noise when I switch it on. And it only gets worse the longer I have it on. I have had to unplug it completely.
Posted by debbiealexis on
Anonymous
  • 1,476 Answers
Debbiealexis,
You have a bad color wheel. It will need to be replaced. I have a tip at http://www.fixya.com/support/r4160054-replace_color_wheel_in_dlp_projection_tv which explains the problem, where to get the best quality parts at the best price and how to perform the repair.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Posted on Feb 08, 2011
What's causing my 2001 hyundai accent to be noisy when moving on the driver side front wheel?
My answer is a bad wheel bearing I explain it in the comment on the prior gentleman's answering of the question I can repeat it if you need me to but I think it's spelled out pretty well in the comment section of the first answer good day.
Jan 19, 2016 | 2001 Hyundai Accent
After sitting for a week or so during extremely cold weather, my 1995 Nissan Altima was hard to start. When I did get it started, it was making a loud rattling sound. The noise doesn't go away, but i
rattling sounds like a busted rocker and the valves are loose. when it doesn't start on the first try or so, that sounds like a head gasket. they tend to start better when its hot because it swells some and improves compression. I had a dodge do that but it will only get worse if that's what it is. If you don't get it fixed now you'll eventually warp the heads and be looking at a head job or worse a new car cause its terribly expensive to fix the longer it goes
Feb 20, 2014 | 1995 Nissan Altima
My 2010 Toyota Corolla LE makes a rattling noise on the passenger side
run the fault codes
no fault codes , check for loose mud flaps , trim , wheel trim etc
Feb 19, 2013 | 2010 Toyota Corolla LE
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My 2006 Toyota Highlander is making a DRONING sound - very loud on the highway- seems to get worse with the steering wheel slightly left and better with steering wheel slightly right. Braking and...
You probally have a bad front wheel bearing , when the noise changes when you move the wheel is typical of a bad bearing.this should be covered under your powertrain warr.
Sep 21, 2009 | 2006 Toyota Highlander
96 Mazda Protege 1.5 L Rattles When Accellerating
possibly the cat itself broken up and rattling in side the silencer especially if more noticeable when engine warmed up.
Dec 12, 2008 | 1996 Mazda Protege
Toshiba 62HM95 62" HDTV Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
