Canon iR1022F, stripes on copy and fax pages. Not removed by recommended cleaning method
Bushara Mahmoud Bushara
    New Friend:
  • 111 Answers
the strips line usually cause by defective cleaning blade to be sure pull out the drum unit and check the drum surfs if you see strips on it that mean you have to replace the cleaning blade
good Luke and thank you for using fixya
Posted on Feb 08, 2011
My canon pc940 suddenly prints copies with a dark stripe running down the middle of each page.
On your computer open the menu for your printer. Somewhere there you will find an icon that initiates a cleaning procedure. It usually takes just a few minutes and the printer wil go through the cleaning procedure on its own.
2answers
The ride side of my faxes and copies are black, any ideas?
Sometimes you may see vertical streaks/black lines on the faxes you receive. Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
to avoid spilling and scattering toner.
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Canon MP-730 It never was a good color printer, the red was not printing, but that is not why I purchased it. But now it the black ink stopped printing altogether, so no incoming faxes, no copies and no...
I can recommend the HP all-in-ones. They are the cheapest per page and are like all HP products - well built and reliable.
I have the L7590 which is duplex printing, photo printing, ADF, Fax, etc.
I don't know of any inkjet all-in-one that is B&W only. If that is what you are after, I would recommend a laser all-in-one like the HP Laserjet 3052 or the Canon imageCLASS MF4150
2helpful
Every Fax we send has stripes going down it making it hard for the receiver to read our faxes. It doesn't happen when we receive fax, print or make copies.
You say it makes copies without the stripes. Do you use the automatic document feeder (ADF) when you make copies, or open the top and lay the paper on the platen? If you get stripes when using the ADF, the ADF scanner area needs to be cleaned. It's the smaller glass area to the left of the main platen glass. Use a damp cloth and remove any dirt or debris.
Canon fax-B840 - Print is "stripey"
No not yet,the problem is the cartridge,sometimes even new cartridges might have a dry printhead
Remove you cartridge,put the printhead side in about 5mm of hot water and keep it there for 5 minutes,take it out and do head cleanning again.
When making a copy we get an ink stripe down the center
open up the document feeder and clean the scanner glass.
Canon b640 problem
By cleaning the feed rollers you the fax will feed beter.Remove the dockfeeder and the paper tray.you will find the feed rollers in the bottom of the paper tray.Take a cloth and a stong soap selution and clean the 2 feed rubbers.
2answers
FAX received full of black stripes
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
1 inch black stripe down edge of page
can you try to post a copy of what you see wrong . and try to do an internal printout " function-6-4-start- under the fax button. "
Tom Chichester
