Question about Logitech Webcam
Was wondering if the quick cam express V-UB2 has a mic and if so why mines aint working
Posted by metaphor229 on
5 Related Answers
Mandyd78
SOURCE: Quick cam messanger ..Mic is not working
I had the same problem. I just re installed the software and it worked fine.
Posted on May 01, 2008
Anonymous
  • 158 Answers
SOURCE: mic
first make sure that you have connected the wire properly into your microphone port at the back of your system
den click start> all programs > accessories >master volume >
click options>properties>then check microphone > then click ok
then uncheck the mute button it must work now .
good luck :)
Posted on Oct 07, 2008
Anonymous
  • 8637 Answers
SOURCE: logitech quick cam express
Normal 0 You need to go to the manufactures site and download the VISTA driver for the camera. Then follow the info below to install the program.
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Feb 04, 2009
Anonymous
  • 8637 Answers
SOURCE: Microsoft vx 1000 wont work in msn messenger
See section C. Windows Live Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Posted on Sep 04, 2009
Anonymous
  • 3 Answers
SOURCE: my Logitech Quick Cam is not working porbly the
el microfono esta incluido en la anterior: Logitech
Posted on Nov 01, 2009
My Logitech Quick Cam is not working porbly the
Lost my webcam installation cd
Here you can download latest drivers for your quickcam pro
Best wishes,
Chillimar
Built in microphone
This isnt really a solution, but a question to my problem. You have your cam working on yours?...My mic works on mines, but not the cam. Can you help me out here?...
By the way, i would give you a solution, just im like 15, i just downloaded it without reading anything and stuff. sorry.>.<
Logitech QuikCam Express...Problem
instalador de camara
como tieneque bagar el listalador de camara
2helpful
2answers
My mic aint working
most likely a broken wire inside. it's dead imo.
Logitech Quickcam Express
Yes it should have. Do this to get it working.
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
1helpful
3answers
How to use mic on webcam?
same problem I can hear my contact but they casn't hear me
1helpful
Logitech QuickCam Express: Microphone not working
The quick cam express and quickcam chats are the only two models built without a mic in the camera.
3answers
Logitech quick cam
HI I LOST MY INSTULATION CD WHAT CAN I DO
Logitech Webcam Logo
Top Logitech Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
