I have a LG LCD TV, I connected my laptop to the tv using the VGA cable. RGB shows video but no sound! I then connect the sound cable from the lapot's headphone to AV..this time I get the sound from AV but no Picture. I noticed on the back of the tv there's a port {AUDIO IN - RGB/DVI} Where can I get this cable? please assist..
Decide if you want to watch the television on your computer
or use the TV as a larger monitor. If you want to view the contents of
the TV on your laptop, you need a video card connected to to the
computer. These cards can either be inserted through the express PCI
card slot on the laptop, or via USB cable. Make sure the video tuner
card supports component video.
Connect the DVI-to-component cable into the DVI port if you
want to use the TV as a large monitor for your laptop. However, if you
have a VGA port, plug the VGA-to-component cable into the VGA port.
Plug the RGB component cables into the component side of the
DVI- or VGA-to-component cable. If you want to watch the TV on your
computer, insert the RGB cables into the TV video card.
Plug the other end of the RGB component cables into the TV.
If you are using the TV as a monitor, plug the cables into the
"Component In" ports. However, if you are sending the TV signal to the
computer, plug the cables into the "Component Out" port (the other end
of the DVI- or VGA-to-component cable that you connected to your
computer in Step 2).
5
Power on the TV. If you are using the TV as a computer
monitor, press the "Video" button until "Component Video" appears on the
screen. If you are watching TV on your computer, launch the television
viewing software that came with the TV tuner card. You can now see the
contents of the TV on your computer.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together.
INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available.
2. Connect the other end of the cable to the side of the RGB adapter with the single input.
3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter.
4. Connect the other end of the RGB cables to an available component input on the back of the TV.
5. Tune the TV to the component video input you used through your television's menu.
6. Turn on your laptop. The laptop should now display on your TV screen.
Your laptop will have a VGA output or possibly a S-video out. For the
VGA you'll need a standard VGA cable. Plug the cable in to your laptop
and the PC input of your TV. If your TV does not have PC input it may
have a DVI input. IF it does you can use a VGA/DVI adapter to plug it
in. If it doesn't have a DVI input you can use the S-Video output on
your laptop with a standard S-video cable. After the connection to your
TV is made you will have to toggle alternate display by pressing and
holding your [Fn] key and pressing F4, or F5, or another F# key. It's
the one that looks like a TV screen. Press once to turn on output,
press again to turn off your laptop screen, press again to go back to
laptop screen only
Every laptop has at least a VGA (computer video connection) and s-video cable port. A VGA cable is preferred if you want to be able to read text on your LCD TV. Check to make sure that your LCD TV has a VGA connector. It's a port that accepts a 15-pin connection so it's pretty easy to spot if it's there. It's just like a computer monitor cable if that helps. Should be able to find it at any local retail store that carries computers. VGA or RGB cable.
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
