Question about Delta Machinery 10" Professional Radial Arm Saw
Hello, I have 33-990 10" Radial Saw and loss the conection of voltage 230 115 switc selector , they have 4 wires to conect, I need the order. Thanks.
Posted by heliboc on
Hans Pearson
  • 2,510 Answers
If you are connecting up to three phase the black wire is the neutral, Connect the other three and if the motor runs the wrong way change over two of the wires - not the neutral.
Posted on Feb 08, 2011
I have to replace the power switch on my Delta Shopmaster 10" radial arm saw. I have the switch, which is a Delta 438010170206S Rocker Switch has (4) terminals. I need to know which wire goes where????
How many wires do you have? The switch is probably a 2 pole, On-Off. If you have 2 wires, connect them to two terminals on one side of the switch (use an ohm-meter to find which terminals make-break). If there are 4 wires, connect the black and white power cord wires to different sides of the switch. Then connect the two motor wires to the two remaining terminals. DO NOT CONNECT THE BLACK AND WHITE POWER WIRES TO THE MAKE-BREAK TERMINALS OF THE SWITCH. This creates a short in the power cord and will trip a breaker.
Oct 29, 2013 | Delta 10" Shopmaster Radial Arm Saw 1-1/2...
How to conect three phase 5 wire conection to 4 wire 380volt three phase from the machine
Identify each of the 5 wires with voltage testing.
Find which breaker serves the 3-wire, and which breaker serves the 2-wire.
--You might have a 3-pole 3-phase breaker (with 3 hot wires) plus a single-pole breaker (with 1 hot and 1 neutral) ... giving a line with 4 hot wires and 1 neutral.
--Or you might have a 3-pole 3-phase breaker (with 3 hot wires) plus double-pole breaker (with 2 Hots) ... giving a line with 5 hot wires and no neutral.
The 4 wires from machine are probably 3 Hots and a neutral, or 3 Hots and a ground.
You need to identify where the ground wire is. One of the 5 wires from breaker box might be a ground.
Copy following links:
http://waterheatertimer.org/How-to-wire-3-phase-electric.html
http://www.electriciantalk.com/f5/
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 05, 2013 | Hardware & Accessories
My oven does not heat up when in fan oven mode, the inner element does not get hot, the outer element does, Both elements get hot when using the main oven full width grill. ...
From your descritpion and if you already replace elements there are two options.
One is that there is an open curcuit either by a loose contact from selector switch to the elements this can be check with a mutlimeter.
The second option the selector switch itself is mulfuction and this normal after long time use since it consist with power contacts they fail to conect after long and you will need to replace it. If your familiar with electric then you can check it with power on and multimeter to see if it conects the elements or not. This operation need extra extra safety and experience.
We have here one side just to see what part you need the cooker selector multifaction switch
Aug 25, 2011 | AEG D5701-4 Electric Double Oven
How to conect fuel lines to poulan chain saw 2375 Le
The hose coming from the fuel tank with the filter on the end goes to the fuel inlet on the carb, this is the conection closest to the alloy pump cover held with a single screw, now take a hose from the other conection on the carb to the shorter ( suction side ) conection on the back of the primer, take a hose from the longer conection ( pressure side ) on the primer back to tank, this just pushes into the tank, just remember that the primer pulls fuel from the carb and dumps it back to tank.
Apr 14, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Hi i have a85 amp when switced on says dc offset check conection ? then it turns off
Hello,the unit is in protect mode from either an internal short(bad amp) or bad speaker or speaker wire.First disconnect all speaker wires from the back of the amp,if the problem is gone then you will be looking to narrow down which speaker is bad (or speaker wire).That can be done with a ohmmeter or a less desirable way and thats a process of elimination simply hooking the speakers back up one at a time till it fails and then thats the culprit speaker.
Feb 13, 2011 | Arcam AVR-100 Receiver
Hello! My brake lights, and turn signals are not
This is not electronical problem.Just missing negative/earth/ at a back lights.Or bad conection.Anyway you need to jump another wire from vehicle body to each rear lamp,conected to negative line inside the lamp.
Apr 23, 2010 | 1997 Volkswagen Jetta
Need fence for radial arm saw
Most guys will attach a sacrificial particleboard sub top about 24" deep (per model) then towards the back of the saw attach a 3-4" square particle board rip, screw it down, then attach a 5/4 to 6/4 square maple fence approx. 4" tall and attach that to the 3-4" wide rip of particle board. then place a additional particleboard top in front of the maple fence. That will give you a 3-1/4" tall fence. all you would need to do is sqare it to the blade and attach it to the saw. Hope this helps
Nov 12, 2009 | Delta 10" Radial Arm Saw
Changing voltage on motor...
pull up the i.s. wiring code from that time
i.s. international standards.
the code change a few years ago
Apr 09, 2009 | Delta Radial Arm Saw
Delta Machinery 10" Professional Radial Arm Saw Logo
Top Delta Machinery Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Delta Machinery Saw Expert? Answer questions, earn points and help others
