Kenmore 17252 Free-standing Dishwasher Logo
Question about Kenmore 17252 Free-standing Dishwasher
The arms on my kenmore dishwasher do not spin.
Posted by cmc_mario on
Anonymous
    New Friend:
Spin it with your hands
Posted on Feb 08, 2011
Hans Pearson
  • 2,510 Answers
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Trying to troubleshoot kenmore dishwasher. water is coming in and out like it's supposed to. doesn't look like the spray arm is spinning although water comes out. help!
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Top spray arm won't spin. No clogs. Water runs fine. Arm just won't spin. Will spin freely if I move it
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
My Kenmore 15632 is not cleaning well at all. The spinning "arm" thing broke off & I can't find my manual to see if there is a way to put the arm back on?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
[['p['
My dishwasher is only one year old.my spinners suddenly stopped spinning
first check the wash arm for stuff in the holes the holes make the arm spin
The top washer arm won't spin - Kenmore Elite 16273 dishwasher
It's probably clogged. Pull it off and check for hunks of food.
Kenmore model 665
You need to check the arm's holes for clogs. If the water is filling and draining well, the only water that circulates is being pushed up through the center hole or tower.
The angles of the holes cause them to be little jets when the water rushes out. No water getting through = no jet = no spin.
Lower spray arm is not rotating
call sears help line thewy have mech that can help
Kenmore Dishwasher Not Cleaning
heatman101
k;kjguit
2answers
Kenmore Ultra Wash Dishwasher
Cyber, did you get down to the chopper screen? If that is clogged with gunk it will restrict the flow and the top arm will not spin. Im going to try to attach a pic of the chopper assy and screen. Catriver..post back
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
