Hi Team.My pc hanging in normal mode. But it is working in SAFE mode.and some times i am getting BLUE screen error. saying that page error and bios update error. after restarting its working fine some times. some time it will not come up. Can u please help me what i have to rectife the problem if i need to update my bios and any other drivers pls help how to do the same. MYBIOS Version/Date TOSHIBA Version 1.60, 8/11/2005 Satellite M40 Thanks & Regards,Nagendra
Posted by nuli_hinagen on
mohd saududdin
    Scholar:
  • 156 Answers
Hi ,
you can try to do system restore from safe mode and check whether it is working fine or not.
If it still now working fine try to go to MSCONFIG and try to disable to startups and check and whether it is working fine.
You can try creating another user from safe mode and try to login with the new user and check it is working fine if it is then might be your account is corrupted and you need to remove it.
In the end the only thing is to do a system recovery where it will load the entire OS once again on your computer.
Posted on Feb 08, 2011
Sourav Dhiman
  • 218 Answers
In the safe mode, none of the background software is loaded and a number of hardware drivers are not
loaded.
Start with the background software. Go to START - RUN and type in
msconfig.
On the resulting dialog windows check the "Diagnostic Startup" and then reboot.
If it works okay, they start adding Services, one or two at a time, until either you find the
faulting service or it starts with all of them loaded. The start with the background software,
adding one or two at a time until you find the bad software.
This is a time consuming task, but it can identify the problem.
You may also have to do this with hardware drivers.
What i think you dont need to update your bios driver. Instead try un-installing any recent hardware change you did to your system.
If still nothing happens try windows recovery console.
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution - Error Code 0xc0000185
Jul 03, 2013 | Sony VAIO Computers & Internet
Krunal
Hi Thanks for your question
What i would recommend to do is in order to return your system to working state is to use System Restore tool. To use it please follow this.
1. When starting System press F8 key few times till you are shown some options. 2. One of the options should be Safe Mode please choose it and press enter 3. Once safe mode is loaded you will be asked if you want to use system recovery or just use safe mode 4. Click no to run System Restore 5. Once system restore is started from calendar showed choose the system restore point when system was working correctly 5. Press next and then next again 6. In few minutes your system should restart and work as normal
Good luck an please let us know if this was helpful
May 12, 2010 | eMachines T3406 PC Desktop
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
Won't boot up.
You have a virus that is about to shut down the hole computer to where you can't even get on it. I would tell you just to reinstall windows to fix it 99% of the time that is the fix.
Apr 10, 2009 | Computers & Internet
Blue Screen of death.
You might try removing the Hard Drive from the machin and slaving it on your other machine. Then running a chkdsk in the command prompt or norton disk utilities. If either fails, backup your data on other machin and reinstall.
Jan 26, 2009 | Dell Inspiron 1501 Notebook
Safe mode boots okay but not in normal boot - no error either
Do you have the original recovery disk? I recommend inserting the recover disk, restart the computer while continually pressing F12. Select boot from CD, press any key when asked, and you would want to do a "repair". That should fix your problem.
Jan 12, 2009 | IBM ThinkPad 600X Notebook
Acer Aspire 5920 will not start up either in safe mode or normal
IF YOU DON'T NEED ANYTHING ON YOUR PC YOU CAN FORMAT IT WITH YOUR WINDOWS OR RECOVERY CD
SOUNDS LIKE YOU MAY HAVE ALREADY LOST FILES
LET ME KNOW HOW THIS WORKS
Dec 27, 2008 | Acer Aspire 5920-6727 Notebook
Having problem with IMB thinkpad R31.
windows xp logo comes on-but then it has a blank screen. wont go in safe mode,etc.i do not have the disk to reboot.
Oct 21, 2008 | IBM ThinkPad R31 2656 Notebook
Computers & Internet Logo
k24674
