Question about i-mate PDA2k Pocket PC
My pda2k is stuck to booting in normal mode everytime i turn it on..pls help me...
Posted by ayanzo_o on
Menandro de Leon
  • 1,138 Answers
Remove first the SD card before booting, see if your unit successfully booted up.
try to replace battery, if battery is faulty it will not turn on successfully.
Posted on Feb 08, 2011
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
I am having asus K8S MX motherboard with amd2800+ processor. when connecting sata hdd it is dtecting in raid mode only .what is the solution to read the sata hdd in normal mode of booting.the raid is...
hi! are you having problem with sata booting system?pls try this solution,
first turn on your computer,and press del when the setup system appear try to look for advance settings or ferephiral setting and look for the sata setup,turn disable setup to enable or on.and press f10 to save setting,
hope this will turn your sata boot to normal mode,,,:)
Dec 07, 2010 | ASUS K8S-MX SIS 760GX CHIPSET SERIAL...
I turn on my computer and i get a box that sais adjust screen and gives a resolution and then goes black, nothing else happens no beeps no booting noise. F10 pops up another screen for 2 seconds then goes...
try to boot in safe mode.To do that.
restart your computer continues press F8 key it will show the option select safe mode
and you can work with that and change the reasoluition and restart the computer work with normal mode..
Nov 13, 2010 | HP Pavilion A610n (PC106A#ABA) PC Desktop
I have an imate pda2k pocket pc and is working good. Out of curiosity i tried hard reset and it ends to align screen. Everytime i made a hard reset the screen show " tap the screen to setup your pocket pc"...
tap and hold on align target until it moves to next corner or next step, if you are using windows 6 or 6.5 you should be very much accurate on taping and holding to align the screen.
Nov 01, 2009 | i-mate PDA2k Pocket PC
Everytime i turn-on my laptop, it abruptly shut down and back to normal like a blink while initializing to start.
It is normal for the screen to go blank while a PC is starting up. Maybe if you could explain in detail what you're seeing it would help us to help you...
Sep 03, 2009 | Computers & Internet
Imate pda2k pocket pc shows align screen
go to start, setup, system, screen, and then click align screen. and then it will give u some small circles to tap on it. u tap correctly on the circles. after few clicks it will automatically tell u that ur screen has been aligned. ur problem is solve by a cute pakistani. pakistan live long. love u.
Oct 06, 2008 | i-mate PDA2k Pocket PC
Companion CD of imate pda2k
the CDis with me. if you want it I can make a copy and send it to you.
mathew
Jul 02, 2008 | i-mate PDA2k Pocket PC
Unable to boot
pls give the following detail
model of notebook
is not able to boot into any of the mode??
May 19, 2008 | Toshiba Satellite A25-S207 Notebook
i-mate PDA2k Pocket PC Logo
73 people viewed this question
Top i-mate Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Jax Planet
Jax Planet
Vincent G
Vincent G
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
