Microwave Ovens Logo
Question about Microwave Ovens
How to dismantle for cleaning - Microwave Ovens
Posted by hodgsonmary6 on
Hans Pearson
  • 2,510 Answers
Don't dismantle anything on a microwave. It is an extremely dangerous appliance, even after the plug has been pulled out of the wall socket. There are commercially available microwave oven cleaners. Whatever you cannot reach and clean with that is best left well alone.
Posted on Feb 08, 2011
How can I remove the vapor barrier on my Panasonic Inverter Microwave to clean the glass!
Inner layer of a microwave door is part of the metal cage that keeps the microwave energy inside and prevents potentially dangerous energy leaks.
To clean the inside of the glass the door will need to be dismantled - some doors dismantle easily and some don't and sometimes the door must be removed in order to dismantle...
Some doors remove easily and some don't...
It is very important the door is reassembled correctly and then tested for energy leakage.
How do I clean between glass and screen on microwave door
With a help of your website a have a nice opportunity to discover new things about shower screens like here https://www.glassstructureslimited.com/shower-screens/ so you can benefit from this informative website too. You are welcome!
Easiest cheapest way to clean dryer vent
Own a chubby cat (trained to crawl through ducts) :) Or just dismantle it and clean or replace the duct with newer ones.
How do I fix the programmed buttons 1 - 5, they stopped working? We can only use the 6 and above numbers.
You must dismantle the circuit board and check if some grease vapours between touch buttons and the the circuit film. Clean with some wet soft cloth.
1helpful
Cannot clean the inside door between glass and mesh - any ideas?
Unfortunately it is not possible to do this without dismantling the door. The mesh is very important for containing microwave energy in the oven cavity. If the door is dismanteled it is important not to damage the mesh and to have the oven tested for possible leakage after it has been re assembled.
Control panel wont work it was sprayed with roach spray it lights up some of the numbeers were working now nothing.
Good day sir/ma,am there are possibilities that the roach spray solution got on the contact terminals. DO NOT Turn it on, let it dry for several days. just to make sure. 3 days is enough. or if you choose to operate it, you must clean dry the circuit board. it requires that you dismantle it, clean the terminals dry and reassemble it again. this may not sound good. you may need to call your service center to be safe. hope this helps.
Sharp microwave model R-395F(S) bought in NZ. 1100W about 30litre. Problem from new, display weak but main problem as some buttons work some don't work and you have to push stop a few times before it...
Hi Lindsay
Sound like you need a new key pad if you have some handy man around you you can replace it, It require dismantle the front key pad remove electronic part and clean then reinstall properly the key pad itself about $40.00 Aus
Let me know if you need part number for that key pad
Cheers
1helpful
2answers
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Top Microwave Ovens Experts
Marvin
Marvin
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
