Question about Toys
Need solution for houdinis cage puzzle - Toys
Posted by smbrobsonsu on
Anonymous
    New Friend:
There is no set solution.
You just keep turning forward and backward on the ball moving up and down the cage and eventually the ball can be extraced from the side of the cage.
There is no special start point.
Once you have the technique, you can do it, literally, with your eyes closed.
Posted on Feb 11, 2011
In moving I am unable to find the AC charger and plug cord for my Electric Houdini. This is brand new - never used !
What voltage is the AC ? 120V 60 Hz ??
Found this but it is for 120V 60 HZ
http://www.rabbitwine.com/replacement-parts/adapter-6-volt-2925-series-647771.html
however if your AC power is 240 volts 50Hz you need to keep looking !
What is an electric houndi - is it a electric cord screw ? this is my guess ?
Important note the 6v DC and the 80mA current rating on power AC- DC pack. If there is any marking on your Houdini similar make sure voltage is 6v DC and current is 80mA or less .
suggest you contact rabbit wine if your ac is 240 Volts and is not 120v 60 hz on the www,rabbitwine.com web site contact link or if DC voltage does not match. Or for advise on if it matches your device.
Feb 02, 2018 | The Computers & Internet
How did houdini die
He took a punch to the appendix.
Harry Houdini
Jul 05, 2014 | Computers & Internet
When it comes to bird cages, why is size so important?
Cage size is a very crucial element in regards to proper bird care. The tail of your bird should never touch the back or bottom of the cage when sitting on their perch. A very general rule to follow is that the width of the cage should be at least 1-1/2 times as wide as your bird's wingspan. Keep in mind that it is not just your bird(s) inhabiting the cage but you will need a perch and most likely some toys. My personal recommendation is to buy the largest cage you can afford.
Aug 29, 2012 | Birds
What size cage should I buy for my budgies?
Even though budgies are quite small, they are very active and need space to fly around and exercise. Budgies need a minimum cage size of 18"x18"x24". Here is a sizing chart that should answer any questions regarding bird species and cage size, along with particular suggested brands of cages to buy.
http://www.bird-supplies.net/size-chart.htm
What's a travel bird cage?
The travel bird cage is usually a smaller version of a normal bird cage. The travel bird cage does not need to be large, nor does it need to be as durable as your bird cage. Be sure that your bird can comfortably fit in this cage for a short amount of time so that it will not become stressed.
Aug 05, 2012 | Birds
Puzzle locations
Puzzle 091 Underground Area-- down the manhole near the giggly little girl
Puzzle 092 Sewer Dead End---- down the manhole
Puzzle 115 Abandoned Tent. ----
Puzzle 118 Village Hall -------
Puzzle 120 In the Sewer ----- down the manhole
I also have answers if you get stuck....................
Mar 10, 2009 | Nintendo Professor Layton & the Curious...
Toys Logo
Top Toys Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Toy Expert? Answer questions, earn points and help others
