Put the printer on
connect a straight cable from printer to your switch in network
now read the instruction manual the default ip is written over there
note it
now from any system in network
open network connections click on properties
goto tcp/ip
click properties
click advance
in tab-ip setting add any other ip of same class which was printer's default ip
ex- if printers ip was 192.168.0.1 add 192.168.0.7
now apply all settings
now on the same computer type the printers ip in any browser
this will give the access of printer to you
change ip setting according to your network class
i.e. assign the printer your network class ip
now you can access the printer from any system in network
do one thing that put drivers of printer in some sharable drive on the network
now you can goto any system add printer from control panel
select network printer
select the printer
when prompted provide location of drivers of printer
you are done .
Correct FAN you
need to change to solve this error is the one that is connected to the J75
connector (FAN103).
With the right side cover removed, the bad fan should be the one on the left side.
If you don't have printer repair experience find someone who has the training.
