Question about Brother HL-2040 Laser Printer
My print View comes blank page? - Brother HL-2040 Laser Printer
Posted by hira30 on
Nikolay Boychev
  • 525 Answers
Try with another toner cartridge, if no result you have to disassemble laser module and clean it with cloth and alcohol.
Posted on Feb 08, 2011
5 Related Answers
Anonymous
  • 210 Answers
SOURCE: prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Posted on Mar 17, 2008
Anonymous
SOURCE: print but blank pages come out - changed the toner
I just had tech from Canon and replace a part that took hime 5 minutes. He said that the part replaced allows the image to appear on paper and it was a common issue.
Posted on Jul 22, 2008
webxcreation
webxcreation
  • 4 Answers
SOURCE: prints extra blank page for every one page of printed material BEWARE SPAM NUMBER 1-800-532-4187
I believe this will solve your problem. It did for me.
delete your printing device and reinstall,
when it asks for your driver, let it search for it.
When your options come up, find "HP" then look for "HP Officejet 7200"
DO NOT install "HP Photoprinter 7200".
This should take care of it.
Good Luck!
Posted on Oct 26, 2008
Anonymous
  • 8 Answers
SOURCE: Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Posted on Apr 30, 2009
Anonymous
  • 168 Answers
SOURCE: Photosmart 7960 prints blank documents; prints from internet ok
If it can print from the internet, it is working properly. I would disconnect the printer from the computer, uninstall the drivers and reboot twice. Reinstall the drivers and hook up the printer when instructed. Make sure that you select this as the default printer. (unless, of course, you have another as default)
Posted on Jul 24, 2009
No print only a blank page comes out
Wrong printer drivers for your computer or else they did not install properly. Also blank page may mean you are out of ink/toner.
How to reset counter workcentre 6505dn?
Try this link:
Read the Billing Meter The total number of printed pages can be reviewed at the Printer Control Panel, on the Configuration Page, and in CentreWare Internet Services (CWIS).
Three meters are available:
  • Total Impressions
  • Color Impressions
  • Black Impressions
The billing meter counts the number of pages that were printed properly.
  • 1-sided prints, including N-up, are counted as one impression.
  • 2-sided prints, including N-up, are counted as two.
    NOTE: During 2-sided printing, if an error occurs after one side is printed properly, it is counted as one.
  • Color documents converted using an ICC profile on applications with the Color (Auto) setting can print in color, even if displayed in black and white. The data prints in color even if it seems to be black and white data on the Display Screen. In that case, the number of Color Impressions is increased.
    NOTE: Grayscale images printed with the composite black setting count as color pages because color consumables are used. Composite black is the default setting on most printers.
  • When printing automatic 2-sided printing, a blank page can be inserted automatically depending on the settings in the application. In this case, the blank page is counted as one page.
View the Billing Meters:
IMPORTANT: The Bill Meters track the total number of pages printed for the life of the printer; it cannot be reset.
To view the total number of pages printed:
  1. Press the [System] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until "Billing Meters" is selected, and then press the [OK] button. The Print Volume Report will be printed.
  3. Press the [Down] arrow button to scroll to the required meter. The number of printed pages is displayed below the name.
  4. Press the [Return] button to exit the Billing Meters menu.
http://wss.support.xerox.com/GTConnect/UnifiedAcceptor/AddWebFramework.Main/site/XeroxProductSupport/product/product_wc6505/lang/en-US/region/region_US/source/DND/Xlang/en_US/Xcntry/USA/prodID/WC6505/KBlang/en/#!view-content/ViewContent/View/contentId/x_6130_en-O8884
Printing jobs are coming out with the text off the page
Some blank paragraphs may have spilled onto the last page. To view paragraph marks (paragraph mark: The nonprinting symbol that Microsoft Word inserts when you press ENTER to end a paragraph. The paragraph mark stores the formatting you apply to the paragraph.), click Show/Hide on the Standard toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.). If you see paragraph marks without text on the last page of your document, delete them. Then click Print Preview on the Standard toolbar to view the document as it will be printed and verify that there is no longer a blank page at the end of your document
We understand that your problem is: Sir, iam jithesh from india,kerala.I have one printer samsung ml1210 printer .give the one print blank page coming automaticaly picking second papper blank page coming...
hello ,
first check your toner cartridge. some time your toner cartridge is damage then black print out is coming.
then check your machine printer and faxes ,check print pages status.sometime their have early print outs.
didnt solve your problem you have to replace main board
4helpful
1helpful
Try to print mapquest directions and sends blank sheet out
Internet printing can be tricky because everything is in HTML which is not designed for printing but for clicking. So there are links and features but when you try to print it can be blank or half pages. Is there a button on the site that says printable view or print these directions or something similar? If you click on that it should allow you to print the page as you see it on your screen.
Kodak printer prints blank pages
When you print from an internet site page and the Kodak box come up on your screen showing that it's printing, do not close this box until you've finished printing or it will print a blank page.
Blank pages
by a different printer, it is the paper sensor and too expensive to fix
1helpful
Prints extra blank page for every one page of printed material
hi,
try this
thanks and regards
agnel
5answers
HP All-In-One HP C7280 (Ink Jet Color Printer/Scanner/FAX)
on that web page look if u have any thing which says printable version or printer friendly
try with that and check
Brother HL-2040 Laser Printer Logo
k24674
Alvin Barnabas
Alvin Barnabas
