Question about Car Audio & Video
Free wire colour diagram or codes for alpine 7292ls please
Posted by kaylouise806 on
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: wire colour coding for radio Holden Nova LF
Car Radio Constant 12v+ Wire: Blue/Yellow
Car Radio Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Posted on Sep 26, 2009
Anonymous
SOURCE: need nissan stereo wiring diagram colour code to
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
Posted on Dec 28, 2009
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: please could you tell me the wiring diagram for a fiat ducato
Check HERE (need register)
Also, its possible that this Reference Guide be interesting.
Hope help with this.
Posted on Mar 23, 2010
Tim Whalen
  • 3074 Answers
SOURCE: a hoover dryer modle no
in the back inside of the dryer there is a wire tied booklet. unplug dryer, moveit out and remove the top back plate and in the left side corner it is there. Hope this helped Tim
Posted on Nov 18, 2010
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: I don't have the wiring diagram for my alpine cva
You can view, download and print the instruction manual with the wiring diagram in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
The installation and wiring details are givem on pages 45-53 of this manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Posted on Feb 12, 2011
How can I find the exact wiring diagram for my 2008 tank vision 250cc motorcycle
no colour coded wiring diagrams anywhere on line
needs the repair manual for it
Oct 20, 2016 • Motorcycles
Alpine wiring diagram
If you contact Alpine they will be able to tell you if there is an adapter that will plug right into your existing OEM harness. If not then, you'll have to figure out Which wires are which on your OEM harness, here is the Alpine wire code:
Alpine wiring help
HU harness color code pretty much universal.
red=ignition
yellow=battery +
black=ground
blue/white=remote turn on
blue=power antenna
pink/black=audio interupt in (not sure if you have one)
speaker wires
gray=right front
violet=right rear
green=left rear
white=right rear
speaker wire with black stripes is negative.
2answers
I don't have the wiring diagram for my alpine cva 1003... Where Can I get a free wiring diagram?
2answers
Need wiring diagram ktp445 to be installed on a NON alpine unit
please, I need wiring diagram for a alpine ktp445.... to be installed on a NON alpine unit.
thx
dave
1helpful
Hi. trying to re-install a pioneer deck where an alpine used to be. can't read the japanese on the alpine wiring to know which wire is for what. What coulour goes to the ignition, what colour is for the...
dnt get confused, follow these simple wiring .......
firstly cut off the old lug from the connected place, make sure you cut each wire seperatly....and you are going ti use the wiring agin, avoid making the wires shorter...
YELLOW..12V+ DIRECT FROM BATTERY...can be joined where alpine yellow was conected.
RED...12V+ IGNITION WIRE..can be joined where alpine red was connected
BLACK 12-, NEGATIVE....BODY GROUNDING
ALL SPEAKER WIRES HAVE +AND-, PURPLE/PURPLE----------WHITE /WHITE-------GREEN/GREEN.......GRAY/GRAY..ALL THESE ARE SPEAKER WIRES, COMPARE THE CONNECTION OF ALPINE AND FOLLOW THE COLOUR FROM APLINE LUG AND JOIN THE PIONEER LUG ....THEY HAVE BAISC COLOUR WIRE AND AHVE SAME TYPE CONNECTION..DO IT
2answers
I NEED FREE DIAGRAM OF CAR STEREO AND AMPLIFIER
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Open Questions:
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
