Question about Samsung YP-T8 Digital Media Player
I have this samsung mp3 YP-U3, it was working months before and out of a sudden it just couldn't be recognized and it became 'unknown device'' It became worse till my laptop doesn't appear anything if I plugged it in the USB port. My mp3 would appear '' USB connecting.. then ''USB disconnected'' Then it starts charging. I have looked for solutions. My device manager does not have a ''portable device'' column that I can uninstall on. I don't think my mp3 is recognized by my laptop at all. I'm so lost.. Please help.. Thank you so much
  • 2 more comments
  • Evon lin Feb 08, 2011
    hmm its just a mp3 USB.. Cable? :l
    its just a USB mp3... cable? :l
    its just a usb mp3.. cable? :l
    oh no its fine.. :) I'll just have to go to a shop and get an extension cable?
  • 215 Answers
It could be a problem with the cable.
Are you using the same cable you have all along?
One of my players works perfectly well on one cable, bit not on another, although that cable works perfectly on another player.
Also, the cable may be faulty, and not making a data connection, though still charging.
Try a new cable.
Posted on Feb 08, 2011
  • 3 more comments
  • motiebrown Feb 08, 2011
    Not everything that plugs in correctly both ends will work properly
    I gave a friend a car charger and a cable to go with it, and a data cable for connecting to her PC,
    She rang as she could not connect, and it turns out she was using the charger cable.
    She described the same as what you are experiencing.
    There are three grades of USB cables.
    USB 2.0, the one you want to use.
    USB 1.0 some of which that i have found to transmit data slower. It will still connect..
    Charging cables, that have only the teo power lines connected.
    And of course the cable may be faulty. It does not get the same gentle treatment as your player.
    All look the same.
    Most of the connection problems i have had myself have been cables not plugged in properly or the wrong type.
    It is unlikely that the computer has fouled up the drivers to let it see the player, though it can happen. Buy iit appears in this case the drivers are there, but just not seeing a data connection.
    That it got worse over a period of time, rather than failed utterly, indicating that the player is working, i would expect it to fail completely and not connect sometimes.
    The socket on the player could be damaged, although if it is charging that is probably not the case, so i am hopeful that your problem is only the cable.
    http://www.google.com.sg/imglanding?q=sa... ypu3
    I dont understand? what cable?http://www.google.com.sg/images?hl=en
    Please forgive me, i was looking at information for the wrong model.
    of course there is no cable.
    That leaves me with:
    The connector on the player is fairly rugged, so it's probably not that.
    Try gently lifting the body of the player when plugged in, I have had devices work that way.
    It possibly means the USB socket you are connecting to has been damaged.
    Try a different USB socket, or sometimes an extension cable can help.
    If it plays after charging for the usual time the battery is ok.
    Sorry about my misunderstanding, but it still sounds like a n old non favorite, a bad connection.
  • app_3rp89989
    app_3rp89989 Jan 17, 2013
    i have the same problem .... i bought it in 2008 . i didn't use it for 3 years because of this glitch. i was thinking of cleaning the use with some alcohol. i'l post again of it works
Anonymous
SOURCE:
I HAVE SAMSUNG YP-U3 BUT MY PC CAN NOT RECOGNIZE HIM. WHAT SHOULD I DO?
Please instal / reinstall driver of Samsung YP -U3 on your computer then paired them again.
This will your samsung work perfectly on your computer.
Regards, Jay
Apr 23, 2011 | Samsung YP-U3 MP3 Player
My laptop does not recognize my SAMSUNG YP-U3
hi,
please install the proper driver for ur SAMSUNG YP-U3 and also update you windows this will solve it thank you
dont forget to vote for me
thank you
Sep 22, 2009 | Samsung YP-U3 MP3 Player
Samsung YP-U3 is not recognized by computer
it is not appering in my copmuters but it is charging.
Jul 23, 2009 | Samsung YP-U3 MP3 Player
My samsung yp-u3 mp3 player is not recognized by my computer
hello sir go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
Then try to format your drvice sir
hope this helpful or if problem stillplease type in comments
May 06, 2009 | Samsung YP-U3 MP3 Player
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
Recognizing samsung yp-u3
my computer say when i go to connect it cannot connect i onli got it today do u know what i cud do??
Jul 18, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-U3 player problem
Here is the link that you need:
http://www.samsung.com/us/support/download/supportDown.do?group=audiovideo&type=mp3players&subtype=flashmemory&model_nm=YP-U3JQPY&language=&cate_type=all&dType=D&mType=SW&vType=L&prd_ia_cd=03040200&disp_nm=YP-U3JQPY
Jun 18, 2008 | Samsung YP-U3 MP3 Player
Portable
Hi Guys,
Downloaded Microsoft Media Player version 11 and installed.
I recall somebody mentioning this somewhere. Now when I go to device manager and select update driver the YP-U3 device driver is found automatically.
Also downloaded other software from Samsung website.
http://www.samsungplay.com/YP-U3/support.jsp?SMSESSION=NO
Merry Christmas
Dec 24, 2007 | Samsung YP-U3 MP3 Player
Samsung YP-T8 Digital Media Player Logo
129 people viewed this question
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
