Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
Need to replace the broken pull string on troy-bilt tb144!
Posted by kulwantsa863 on
5 Related Answers
Anonymous
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
Anonymous
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Posted on May 05, 2009
Anonymous
  • 4 Answers
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
Ragoo Monistere
  • 41 Answers
SOURCE: TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
Posted on May 07, 2009
lilmikew99
michael
  • 122 Answers
SOURCE: TB144 pull cord does not catch, pulls free--no start
yes exactly what i would do sounds like the springs are either worn or gummed up or just broken on the dog ears
Posted on May 11, 2009
Troy bilt pull cord wont retract
Recoil spring is broken or slipped out of retention slot. Coil needs to be retentioned or replaced. Unless you have done this before I recommend taking to pro. This is easy job if you have the jig but almost impossible if you don't.
Jun 29, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a troybilt tb-144 4 stroke mini tiller. The pull cord, pulls and retracts as it should, but is not engaging the engine when pulled...
remove the top cover. look inside while pulling rope briskly, you should see two dogs fly out and retract when the cord reaches its end. if not, check for dirt in the system and clean out. if no dogs, you will have to remove the system from the housing, be careful of the spring. check for any broken drive parts. also check flywheel cup for damage where the dogs come into contact with it.
Apr 15, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Cant get the cap off to replace the string on a troy built trimme
The cap just pulls off but yes it will be tight if its the first time you have ever removed it to replace the nylon string. Use a small flat screwdriver to lever under the edge of the cap and pullng at the same time but be carefull not to break the plastic surround
Aug 02, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
May 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Troy-bilt 4-cycle Garden Cultivator TB144 pull cord not rewinding.
This type of pull starter design is very poor and fails often. Cheap parts and cheap design leads to poor performance and yet Troybuilt still doesn't give free parts or an upgraded design.
Mar 05, 2009 | Garden
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
223 people viewed this question
Top Troy Garden Experts
Dennis Key
Dennis Key
Marvin
Marvin
wadingriver
wadingriver
Are you a Troy Garden Expert? Answer questions, earn points and help others
