Question about Robitussin Cool Moisture 1 Gal. Humidifier
Model RCM-832. On/off switch works, blows air but no moisture seems to come out. I left it on for at least one day and the water level in the tank remained the same.
    New Friend:
    Problem Solver:
  • 9 Answers
First check humid-stat setting make sure that the room is not above setting. Second check that float(water level) switch is being made. Hope that helps
Posted on Feb 08, 2011
6ya staff
SOURCE:
Wont run in unit lift out and lift level control works fine put it back in unit [ very tight fit] lift level control wont work
Hello.
The GE humidifier adds a continuous stream of cool mist intothe air, giving moisture to dry air due to cold weather or dry climate or tohelp those who desire additional moisture because of respiratory problems orallergies. Sold online and in many department or home retail stores, thehumidifier requires regular cleaning and maintenance for proper functioning andto help keep mineral scale or bacteria from growing in the humidifier. ·1 Connect the power cord on the GE humidifier firmly to a power outlet if thehumidifier is not working. Replace or reset the circuit breaker as necessary.Turn the power switch to "On" if there is power but the unit is notoperating. · 2 Fill thewater tank to the "Fill" mark if the mist output is low or notpresent. Wait 15 minutes after filling the tank and before starting thehumidifier to allow the wick filter to absorb the water for proper function.Turn the humidistat knob to a higher setting for higher output. · 3 Check the capon the water tank and close the cap firmly. Check the rubber tank cap ring onthe cap and reseat firmly to help provide a better seal. · 4 Replace thewick filter with a new wick filter, available through General Electric, if thewick filter inside the base turns brown. Replacement parts may be ordered bycalling 877-207-0923. · 5 Clean thewater tank with vinegar and a soft brush if the water begins to get cloudy.Rinse well before refilling with water. Use cold water in the tank, as warm orhot water may make the water appear cloudy. · 6 Loosen thetank cap slightly if the humidifier cycles on and off unexpectedly. Turn theknob to a higher or lower setting. Thanks.
Sep 09, 2011 | Sunbeam Humidifiers
WATER LEVEL FLOAT DEVICE PREVENTS UNIT FROM TURNING ON,EVEN THOUGH WATER TANK IS FULL. REMOVED SOME FILTER MATERIAL WITH NO EFFECT. FLOAT IS FREE WITH NO RESTRICTION.
These hints are from the air o swiss webpage.
Q: No mist / unit is not working / empty indicator keeps flashing
A: Fill up the water tank. Check if water is flowing through the demineralization cartridge (attached to the water tank cap). If the water tank is full but there is only little water in the base it indicates that the water is now flowing through the demineralization cartridge.
  • Wait for 15 minutes to allow the mist to come out of the unit.
  • If the unit is not working and the empty light is not flashing you might have set the desired humidity too low and the current humidity level in the room is higher. That is why the unit switches off automatically.
  • If the empty indicator continues flashing and the tank is full, water is not flowing through the cartridge. Exchange the cartridge or the granules in the cartridge after 2-3 months, in areas with hard water exchange the cartridge after 1 -2 months. However, the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit does not reach its full performance.
If the granules are new, see the following instructions:
  • Make sure the cartridge and/or granules were soaked for 24 hours, water takes longer to filter through dry granules in cartridge and into the base. Next, remove 2 tablespoons of granules from the cartridge, and throw them away. Too many granules in the cartridge it does not allow water to flow from the tank to the base.
If your issue is with the float and not the mister, then you have to make sure the float is tripping the micro switch that turns the machine on. Some units the filter will not allow the float to hit the switch if the filter is not installed correctly. If everything is in correctly and the float is tripping the switch, then the micro switch must be faulty.
Apr 04, 2011 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
I bought a hunter humidfier about 2 years ago and now i am using it for the first time. I took all the plastic off around it and opened up the top to make sure the filters and everything is in place. I...
Hunter carefree humidifiers use a reusable and washable wick this method of humidifying does not produce a fine mist like many centrifugal (cool misting)humidifiers. The fact that it is producing cold air seems to indicate it is working. However it would not hurt to check the water intake for blockages it also a good idea to run these models on high for several mins when starting this ensures that water is being pumped up.
Mar 07, 2011 | Hunter CareFree Plus 33222 Humidifier
I have 2 of these humidifiers and neither seems to be dispensing moisture into the air. The fans work fine and the filters are new. I am using regular tap water and have placed them in a room and ran...
If your "tap water" is from a well, the humidifier may be clogged with mineral scale. Even if it is not well water, your municipal source may have a high mineral content.
Using a 50/50 solution of White Vinegar and water run through the system will usually clean the mineral scale out. In the future, I would recommend that you use Bottled Distilled Water. You can buy it by the gallon, inexpensively at grocery stores or pharmacies.
Feb 24, 2011 | Holmes Products HLS1200-U 1 Gallon...
The humidifier appears to be working (with sound ) but is not collecting any water-cleaned the filter and still the same -the lit up area where it usually has the numbers is sitting at P2- I have lost the...
Alison -
A humidifier will not collect any water. A humidifier has a tank that you fill with water. The water is released / forced into dry air to make it moist, usually by a fan or ultrasonic method.
A dehumidifier has an empty tank that gets filled by the appliance extracting moisture from the air. The tank will have to be manually emptied periodically, otherwise the safety / water level switch will shut the unit off so that the tank doesn't over flow.
I suspect that you meant to say dehumidifier.. and if so, please provide the manufacturer's name and model. The "P2" indication will be difficult to interpret without knowing the manufacturer's info.
Nov 22, 2010 | Humidifiers
Motor runs, but does not collect any water in yank
Make sure any air filters are clean. Check to be sure the evaporator and condenser coils are very clean. Also could the humidity level in your home just be very low right now and just no moisture to remove? If all of this fails it could be a compressor problem or a refrigerant level issue. If this is the case determine if it is worth the expense to repair.
Good luck
Mar 28, 2009 | Whirlpool AD25BBR 25 Pint Per Day...
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
No moisture
Is the level of water dropping? If so, the humidifier is working. If you have a cool air humidifier you won't see any steam or anything at all. You will just feel cool air. Watch the water level and see what happens.
Good Luck.
Feb 23, 2008 | Hunter 33201 Humidifier
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Left Tank won't empty
Eureka! Solved my "left bottle not emptying" problem. The problem was not with the bottle but that the top of unit which houses the on/off switch was not seated properly. It takes only a very slight difference in water level for the float to activate the switch, therefore if the top is raised even 1/4" the unit will shut off before the water level is low enough to allow the left bottle to drain.
Feb 26, 2007 | Emerson HDC12 Humidifier
Robitussin Cool Moisture 1 Gal. Humidifier Logo
390 people viewed this question
Top Robitussin Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you a Robitussin Humidifier Expert? Answer questions, earn points and help others
