Question about LG LRE30451 Electric Kitchen Range
The oven will only preheat to about 285 degrees. We took the heating element in to get tested and it was fine. What else could it be?
Posted by nateandmeg61 on
Kevin White
  • LG Master
  • 1,902 Answers
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Feb 08, 2011
My oven shows an E7 on the control panel of my Maytag che9800bce
the tech sheet says " Function key shorted or stuck button" ,I suggest you to try to play around with the buttons and test the bake element for continuity
Mar 07, 2013 | Kitchen Ranges
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153992&diagram_id=1251523#d1251523
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Oven temp maytag MER5770
check your element if thats fine u need to replace your erc and possibnly your oven sensor
Mar 19, 2009 | Maytag MER5770 Electric Kitchen Range
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Kenmore oven - Not heating up
Check the BACK of your temperature knob for an adjustment. I was ready to replace my heating elements when I accidently discovered the adjustment. Made the adjustment and no more problems. My oven now stays within 4 degrees of settings.
Aug 25, 2007 | Equipex PZ-330 Electric Single Oven
LG LRE30451 Electric Kitchen Range Logo
511 people viewed this question
Top LG Kitchen Ranges Experts
Marvin
Marvin
Ismael Rodriguez...
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
