Samsung SlimFit TX-T2782 HDTV Logo
Posted on Feb 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The color on my Samsung Slim Fit TV suddenly blipped to pink and blue. When I turn it off and back on, it comes on with a green line across the middle of the screen. What's up?
Deepak Mathur
Level 2:
Habit-Forming:
New Friend:
  • Expert 101 Answers
  • Posted on Feb 08, 2011
Deepak Mathur
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
101
Questions
0
Helped
50143
Points
188
This line shows that there is failure of vertical output stage,may be due to high supply from internal power supply of TV set,check the voltage of the vertical output stage,and after rectification of supply problem replace vertical output IC to get this problem solved.
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Tv has a pink smudge across the top of the screen and colors at tp of screen do't seem to align pink and blue and green. Tv was banged when carrying up 2 flights of stairs.
Your convergence has failed and need to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed.
You can get the parts and instructions from www.TvRepairKits.com
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
1helpful
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
1helpful
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
