Fan motor hesitates when starting and then it will run
Posted by john_f_brosn on
Robert Moller
    Guru:
  • 1,524 Answers
Change the capacitor.
Posted on Feb 08, 2011
89 ford probe hesitates when leaving a red light, then runs fine otherwise, fuel filter?
Engine Runs Rough, Stalls, Hesitates on Acceleration, Hard ...
repairpal.com > Problems > Ford > Probe
Ford Probe Engine Runs Rough, Stalls, Hesitates on Acceleration, Hard Starting, Poor Performance. This is a verified problem based on 9 reports. Learn more ...
Starting Problems - 1997 Ford Probe - RepairPal
repairpal.com > Questions > Ford > Probe > 1997 Ford Probe
Dec 5, 2010 - Starting Problems on 1997 Ford Probe ... If the engine runs rough,stalls, hesitates on acceleration, is hard to start, or has generally poor ...
A new misfire/hesitation on accel. Problem.. - ProbeTalk.com Forums
forums.probetalk.com > Tech Section > 2nd Gen (93-97) V6 2.5L
Feb 05, 2016 | Ford Cars & Trucks
Do you think it could be the fan capasitor?
if even after changing the capacitor the fan does not run on its own , so it indicates the weak fan motor .but before that check whether the bearings are chocked up ,sometimes even choked bearings cause this type of problem.
for any further queries feel free to ask.
thanks
Sep 18, 2008 | Dometic Rooftop RV Air Conditioner
How to test radiator fan motor
first check fluid lvl then check fuse for fan then unplug temp sensor switch and use jumper wire in the wire socket fan should come on if not check temp sensor switch.
Oct 31, 2014 | 2002 Chrysler PT Cruiser
Kenmore 22 porcelain plus
Will you can not lubricat fan motor you will have to replace it because it will just keep doing it right on that is the only way you can fix it.
May 01, 2014 | Refrigerators
Small engine hesitates on start after worm up it runs ok
thats common for motors to hesitate till they warm up but you can adjust your carb for more fuel flow this take care of hesitation
Apr 18, 2013 | Briggs & Stratton Garden
Cooling fan cannot get started by itself once it starts....if you give it a little touch it will start. Could it be the fan motor?
Yes that sound exacly like a bad motor,by giving it a little help and it starts and runs that means power is at fan motor to let it run,it would not run if power wasnt there so since power is there everything else is fine and sending power to fanmotor and it just wont start. By replacing that fan it will run byself without and help. Reply back with EXACT model number and i'll give you the part number so you can get replacement motor. and while i think its the freezer fan motor your talking about?is it the freezer fan or the one by the compressor?
Gene
Aug 17, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
My fan doesn't start right away when the switch is turned on. Then as it is starting up it squeaks and hesitates. Seems like a "gunked-up" problem but I can't remove the impeller blade assembly from the...
The fan blade can be removed from the shaft. You just need to pop the lock washer off and pry the fan blade. You most likely will not be able to remove the fan blade without damaging the blade. You can buy the replacement fan blades online. The part number is 5901A000. Here is a blog on the entire replacement motor assembly. http://nutoneproducts.typepad.com/nutone-products/2009/08/nutone-0695b000-replacement-bath-fan-motor-for-model-qt80.html
Oct 05, 2009 | Broan-NuTone QT80 Fan
Evaporator fan did not start running when condenser fan started.
I don't know why there would be much of a delay between the condenser and evaporator fans coming on. If you have diagnosed it as a bad motor, that's probably correct.
But the motor could just need cleaning and lubricating
Apr 28, 2009 | Kenmore Refrigerators
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
