Question about Reddy R60A Utility Heater
Heater runs for 2-3 minutes then shuts off. unplugged to reset and it runs again for less than minute then shuts off again
Posted by orsak4 on
Kens Repair
    Habit-Forming:
    New Friend:
  • 67 Answers
Clean or replace your photo cell. Make sure your air pressure is set right,Remove your nozzle and blow air thru it . To test your photocell use a muti-meter hooked to two wire and hold flashlight over the end of boot see if ohms increase if not it junk,replace it.
Posted on Feb 08, 2011
I have an Bionaire BPH1520 Micathermic Electric heater which will not heat up. I turned it off after use and now will not heat up when switched on. Digital display still lights up? Is there an internal...
AUTO SAFETY SHUT OFF
The heater has a built in safety device which
will switch off the heater automatically in case
of accidental overheating. It can only resume
operation when the user has reset the unit. For the
BPH1520 (OH)will display in an overheat situation.
To reset the heater:
1. Unplug the heater and wait for 30 minutes
for the heater to cool down.
2. After the 30 minutes, plug the heater in
again and operate normally.
fOR FUTURE REFERENCE HERE IS A COPY OF THE OWNERS MANUAL
http://www.bionaireuk.co.uk/Manuals/MANUALS/BPH1520-UK_43_91313392.PDF
Jun 07, 2011 | Bionaire BPH1520 Micathermic Electric Wall...
THE HEATER RUNS FOR 2-3 MINUTES AND AUTOMATICALLY
Thermal safety is tripping, clean it out , no repairs viable for theses units,
May 23, 2010 | Honeywell HZ365 Ceramic Compact Heater
The heater comes on for a few seconds then shuts off but once or twice a week it comes on and operates like a normal heater
Mine does the same thing. I have a gas heater. It will fire up- run for less then a minute then shut off. then 2 minutes later does the same thing. I'm thinking of going with a differeny brand because this is using a lot of gas evertime it fires up just for a minute. if I turn it up it stays on till it reaches the temp then does that on off thing again. i think it is just the so called "feature" Honeywell is claiming to maintain the temp in our home, not realizing it is wasting your gas or electricity.
Feb 23, 2010 | Honeywell Programmable Thermostat Heater
The heater keeps shutting off, i unplug and wait a few minutes, then try again it works for a few more minutes then shuts off again.
Defective thermostat is shutting it down before it reaches the correct temperature. Essentially the thermostat is acting too sensitive.
Finding parts could be tricky probably worth replacing for the potential repair cost.
Jan 02, 2010 | Sunbeam LowProfile Space Heater
Sunbeam SLP3310-UM shuts off after 2 minutes. I unplug it and hear a relay clicking after a couple of minutes. Replug it, and shuts off again after 2 minutes. It worked fine last year, not this year.
It's broken --- call Sunbeam customer service (888) 264-9669 and have your receipt and serial number ready. They are aware that these have faulty switches in them.
Nov 26, 2009 | Sunbeam Pool & Spa
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Heater shuts off unexpectedly
I would suspect that either the reset (HA3003 Safety Control) or the photocell (HA3019) is bad. For test purposes only bypass them one at a time- see if the unit ron OK.
Troubleshooting tips
hA3003
Apr 18, 2009 | Heating & Cooling
Blinking error codes?
Unplug the machine for 30 minutes , plug it back it, start it for 1 minute, unplug it again for 5 minutes then plug back it and it should work. If not then write back with the error codes so further diagnostics can be done
Apr 08, 2009 | Kenmore 62602 Electric Dryer
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy R60A Utility Heater Logo
221 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Superior Maintenance
Brad Scarpetta
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
