The manual... Distorted sound from the Soundbar. Change the Trim Level switch setting to a higher number. The woofer seems to have interference with its wireless signal. Try changing settings of the Wireless ID switches on both the soundbar and bass unit. <<<<<<<<
http://www.retrevo.com/search?q=Boston+Acoustics+TVee+Model+Two
Page 7
Check the signal source to be sure the distortion is not originating there. <<<<<<<<<
The bass unit could be too far from the soundbar to get a good signal. Try moving it closer.
What is the source device that results in static? How is it connected?
have you tried this control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer
make sure you have an earth
******** before touching any parts inside your computer
click start control panel
sounds and audio devices select advanced there might be a tick in the mute box
untick it or select audio from the microphone drop down list make sure you
have the right one selected and in the volume box make sure the microphone box
has a tick in it or select the voice tab and make sure that you have the right
media selected also select volume make sure the box for microphone has a tick
in it
hope this helps
