Plumbing Logo
Posted on Feb 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an american standard kitchen faucet with a one piece handle, spray head, and faucet will swing side to side. It has lost pressure on both hot and cold water. Pulled faucet checked incoming water line good pressure.
  • Anonymous Mar 15, 2014
    My faucet 7560C is hard to turn or swing from side to side. What can I do?
Anonymous
Level 3:
  • Master 528 Answers
  • Posted on Feb 08, 2011
Anonymous
Master
Level 3:
Answers
528
Questions
0
Helped
274227
Points
1396
Check the aerator and see if it is getting plug up.
  • Anonymous Jun 06, 2012
    How do u take the aerator out
  • Ian Lulham
    Ian Lulham Jul 11, 2014
    The aerator should screw into the faucet (internal threads). The aerator has a screen and the plastic aerator. If the screen is clean there may be trash in the aerator.
Replacing Sprayer on Kitchen Sink?
Should be able to purchase sprayer head only at any store that sells taps and hardware to go with them. I got a replacement at a plumbing store in Chatham Ontario.
Our American Standard kitchen faucet has become hard to swing from one side of the sink to the other. What could be causing this? Is there a bad part?
Hi! If there are no leaks from around the spout, you can remove the spout and apply silicone lube to the spout o-rings and resemble. If it is still hard to move ,replace the o-rings.
1helpful
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
5helpful
2answers
Kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Installed new faucet worked then all water stopped
If it has a side spray the diverter might be stuck. try flicking the spray handle on and off.
Hi folks, seems stupid, but I'm changing the cartridge on my american standard kitchen faucet. If I line up the holes on the botton of the cartridge with the holes in the fixture, I don't have the ability...
Most likely you need to adjust the hot limit safety stop which restricts handle swing to limit the high temp of the water and avoid scalding... check out this link to the install manual for your faucet. Also includes detailed diagram of cartridge alignment just in case you need it.
http://www.americanstandard-us.com/Assets/pdfs/as/install/Install_1859.pdf
Hope this helps, Tripp
Slow and nonexistent water flow.
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Spray lock button does not lock in position
sadly not much to be done there but replace the head
Top American Standard Plumbing Experts
john h
Paul Carew
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
