Question about LG LFX23961ST Stainless Steel Bottom Freezer French Door Refrigerator
I need help my refrigerator keeps freezing everything and i have it on the highest setting. what to do?
Posted by sexxymami161 on
Anonymous
    New Friend:
  • 11 Answers
You went the wrong way on setting, go to lower setting,this should help from freezing.
Posted on Feb 08, 2011
Haier minifridge freezing everything
My mini-fridge did a similar thing, until I realized that managed to put on the wrong temperature knob. It was technically backwards. They may have done this to you. I mean, it is a longshot, but try putting it on the highest setting to see if that helps. If it does not, you're most likely dealing with a faulty knob that's not actually changing the settings on the thermostat.
My kenmore fridge 253.53612300 was set on the highest # for cooling and barely worked for about a year now it is freezing everything in the fridge what is going on
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
2helpful
Ice maker not working. refrigerator is freezing everything. seems to run all the time.Help!!!!!! It is an Amana about 10 yrs old.
if you have the settings correct then the cold control(ref setting) is bad. but some older models use a baffling system which confuse some people. the freezer settind turned to the lowest setting make you fridge colder. when you put the freezer on the highest setting it allows less airflow. which in turn keeps ref warmer.
2helpful
Freezing Items in refrig
number one is the lowest setting...try that
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
GE GSS27RGMFWW Freezer Not Freezing..
Yo u ha ve to Change the bimetal that its located in the freezer.
Hello. I just now found your post here on fixya. Do you still need help with your frig?
Samsung RS2545SH Freezing Everything
Sounds like a thermostat problem. There will be a thermostat sensor inside the fridge usually inside the interior light housing.
LG LFX23961ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
Top LG Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
