Question about Whirlpool Duet GHW9150P Front Load Washer
I have front load duet the door locks the water starts to come in then it shuts completly off so you have to hit the power button a couple times to get the door unlocked to try again tried 3 times in a row Thanks Bob
Posted by bobfrank on
tara808
    New Friend:
Your main drain is probably clogged up. If you can ger your book and unscrew the front pannel there should be a twist of to a drain under there. You will need a bucket or some way to catch all the water when it comes out probably have a sock or undergarment stuck keeping it from draining. They have a shut off to keep you from burning your motor up. Let me know if it works.
Posted on Feb 07, 2011
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washing machine will not start a cycle.
sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Nov 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start/lights on
ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW1 W/POOL WASHER
if dorr does not lock then the fault is door interlock
Dec 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Front Loading Duet Washer will not start
You have to set your programme FIRST, then put the "on" switch. Try.
Mar 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
55 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
