Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Working offline. Printer will not print from word or excel.
Posted by gnevin_22 on
JDTec
  • Kodak Master
  • 4,338 Answers
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
OR:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it's set to print online
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Feb 07, 2011
Printer wont print says its offline
Dear
Click on START-PRINTER AND FAXES-right click on the PRINTER ICON-click on USE PRINTER ON LINE.
If this is not working connect(replace the cable with a known working cable) the usb cable at the back panel usb port(or change the usb port) of the PC.
If this is not working un install the printer driver and reinstall the same.
If this is not working the printer hardware failure may be there you may need assistance of trained personnel.
Thanks.
Feb 25, 2015 | Office Equipment & Supplies
Cp1525nw appears offline
If the system is unable to detect the printer, it will put the printer in offline mode. In this condition you won't get any print outs..
1. chk usb cable
2. un plug the usb cable, un install the drivers, plug the usb cable & chk new hard ware found?.. if not there is usb port issue, chk system usb port/s are working or not.. if yes
3. Replace printer formatter assmbly...
This printer network unable printer, why cant use through network? instead of replacing the formatter assembly...
Jan 02, 2014 | HEWLETT-PACKARD CP1525NW Laser Printer
Printer offline which was working earlier
My computer detected printer offline. I have just used to print some documents. So, please advise what is the problem.
Mar 28, 2013 | Canon Black Pixma Mp 280 High Quality...
When i print from hp deskjet D1560 it dose not print. It automatically shows offline when i print even though it is not offline. And it dose not print self test page also. pls give an instant...
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Aug 19, 2011 | Office Equipment & Supplies
My brand new Canon IP 100 pixma printer wont print cause it's saying "offline." I've turned it off and on numerous times. What can i do?
Hi, please follow this instruction to make your printer back to "online". Notice that i have used Epson Stylus Photo R230 as a model for the instruction, but this procedure also works with canon.
1. Please try to print a document. (word, excel etc.), 2. Now, if you already notice that your printer is "offline" by clicking the printers icon at the task bar.
The task bar can be found in the lower right part of your screen.
3. All you have to do is, Click on the "printer" tab 4. And then remove the check mark at "user printer offline" by clicking on it.
5. Once done, you will notice that the "use printer offline" will disappear and then let's you print the specified document again.
I hope this helps.
Aug 09, 2011 | Canon Office Equipment & Supplies
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Printer offline? won't print
please go to start menu, select printers and faxes or control panel to select printers and faxes open it, right click on your printer and scroll down to select use printer offline. then u are safe to print start ur printing. dont forget to rate me when it works am sure it will work. thanks
Jul 17, 2009 | Brother HL-2040 Laser Printer
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
558 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
