Question about Fantom Vacums FM780 Twister 700LX Upright Vacuum
Describe your fantom vacuum fm 780 fuses Problem If a fuse goes out where do i find it on the vacuum to replace it?
5 Related Answers
Anonymous
SOURCE: Fantom Canister Vacuum parts
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12055&thid=723654
Posted by jaybird73 on Jun 30, 2008
Hi, Don. I'm in need of a part for my Fantom Canister. It's a little difficult for me to describe but here goes...the part is the small metal "pins" that are found in the connection between the hose and the motorized floor attachment. There are normally 2 found in that area, they are about an inch long and I guess they pass the electricity between the hose and attachment. Any help is appreciated.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sound so me that it could be a lower wand with the pins in the end or the part of the power nozzle and the part that the lower wand fits into is called the gooseneck and that can be replaced as well. If it is part of the hose then you may have to replace the hose and that could be expensive or over $100.00 or more, as an estimate. The best place to get the information is the owner’s manual under trouble shooting or to cal the Fantom factory of which I will provide for you @ the bottom; or your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
Rob Ristin
  • 97 Answers
SOURCE: believe the fuse is blown
Unfortunately Fantom has been out of business since about 2001, so parts are very difficult to obtain. Your best bet would be to try to find the parts online or possibly at a vacuum store, but I would be very doubtful that you will be able to find the parts.
Good luck,
-R
Posted on Aug 04, 2008
defrankond
CJ C
  • 66 Answers
SOURCE: fantom fury vacuum
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®? a.gif fantombeltchange1.jpg
  1. Unplug the machine.
  2. From the front of the machine, remove the collection bin.
  3. Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
  4. To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
  5. Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
  6. To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
  7. Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
  8. Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
  9. Replace the brush by aligning the metal end so the points face downward. (Figure 3)
  10. Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
  11. Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
Posted on Nov 30, 2008
Anonymous
SOURCE: i cannot find a vacuum cleaner bag for my fantom
I have bags if you still need them.
Posted on Sep 24, 2010
awa13
AWA
  • 78 Answers
SOURCE: I have a fantom 741b twister, while vacuumming stopped. I have cleaned everything. Will not start. Whereis internal fuse
Sorry, but I do not know as I am unfamiliar with this model.
Posted on Nov 24, 2011
Manuals vax
Check the fuse, replace if blown WITH SAME RATING FUSE. If there has been any damage caused to the cable, have this replaced by A QUALIFIED ELECTRICIAN.
Aug 15, 2014 | Fantom Vacums Vacuums
Fantom falcon vac
see you instruction manual or download from www.retrevo.com or www.fitness.manualsonline.com
see the diagram. God bless you
Jun 19, 2012 | Fantom Vacums Lighting Canister Vacuum
My Fantom Lightning canister vacuum won't turn on at all, worked fine last time I used it.
You need to turn over and remove the case to get to the motor.When you get to the motor you will see a white wire going to the motor from the switch,it has a white cover over the wire,pull this cover back and there is a small fuse that is probably blown.You can check this with a electrical tester.If this is not blown the heat sink that is connected to the fuse may be bad.These parts can be found at Radio Shack.
Jan 12, 2010 | Fantom Vacums Lighting Canister Vacuum
Acin and sparkin
HI
Im guessing its a break in the cord where it goes in by the switch
Feb 18, 2009 | Fantom Vacums FM740 Twister 300SE Bagless...
Fantom cyclone xt
Go Fantom Vac site ,type in model #.A PDF
booklet will describe it.
Aug 20, 2008 | Fantom Vacums XT450K Upright Vacuum
Believe the fuse is blown in my fantom fm760 vacuum. put the wrong kind of headlight in and when i turned it on it blew the breaker as well. took apart and the fuse is part of the powercord.
Good luck,
-R
Aug 04, 2008 | Vacuums
Go Ahead. Use Us.
Jun 30, 2008 | Fantom Vacums Lighting Canister Vacuum
Fantom Vacums FM780 Twister 700LX Upright Vacuum Logo
77 people viewed this question
Top Fantom Vacums Vacuums Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Tom Chichester
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
