Question about Candy Washing Machines
I have a ICW101 TR H/C It washes but makes a banging noise on fast spin. It also gives a burnt smell.
Posted by neil995 on
Robin Bonathan
  • 699 Answers
The dampers on the underside of the drum have failed.
They are like shock absorbers.
You need to tip machine onto its side to see them.
Disconnect power and pipes from machine first.
The machines have concrete blocks in so get someone to help you if you want to look or call out service engineer, they are not cheap part unfortunately.
Please dont forget to vote if you liked my answer
thanks
Posted on Feb 07, 2011
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Banging when spinning and rubber smell
if the basket wabbles like crazy, could have a cracked spider that holds the basket
Mar 01, 2014 | Washing Machines
It has gotten very loud and makes banging noise in spin cycle, now I have found hard plastic strips after wash and smells like burnt rubber.
Hello. Most likely the transmission has gone bad resulting in dislodging of the tub causing the plastic and the burnt rubber. This is probably not worth repairing unless it is under warranty and less than 3 years old. This is the perfect time to get an energy star washer which has a government rebate of 75 dollars. Joe
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Very loud banging on fast spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 17, 2010 | Whirlpool AWM8113 Front Load Washer
Washing machine went bang and smells burnt
May be hard to find what went bang for you/ could be motor. / Heater/ wiring/ printed circuit panel, Advise get engineer to check.
Nov 28, 2009 | Coffee Makers & Espresso Machines
My Kenmore washing machine had a faint burning smell.
i would let it sit for an hour. more than likley what happened was the motor overheated a little because it was trying to spin in an off balance situation. give it a break for a while the next load that you do keep an eye on it and see if you smell anything if you do then you have a problem. But 99% it is ok.
Jun 28, 2009 | Washing Machines
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
The spin bang all over the machine
is it actually spinning or jsut making banging noise. if just noise
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Jan 16, 2008 | KitchenAid KAWS850LE Top Load Washer
Washing machine
This sounds like the brakes have gotten some residue on them and are grabbing way too hard. The banging is the tub stopping too fast and the torque from this makes the tub bang into the cabinet. Just one bang at the end of a spin. Is this correct???
Nov 25, 2007 | Kenmore 23012 Top Load Washer
Washing Machines Logo
187 people viewed this question
Top Candy Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
