Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera Logo
Posted on Feb 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Card locked how can i unlock it - Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera
Anonymous
Level 3:
Guru:
  • Master 2,178 Answers
  • Posted on Feb 07, 2011
Anonymous
Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390706
Points
6614
There is a switch on the side of the card.
1helpful
1helpful
Sim card not supported
If the Sim card Not support means it may locked to network.You need to unlock it...You can get the network unlock code from the site Onlinegsmunlock.com/samsung/rs7wp8/ for SAMSUNG GSM Network locked Phones and unlock it from Network lock.You need to specify the Model?
ALSO check whether it not support only one Sim card,if that problem means it may CDMA Network,OR may Sim card problem.If it not support other Sim card and support only one Sim means it's Under Network lock,You need to find the network,country it locked now and unlock it using the Unlock code,Only GSM Network lock Phones can be unlocked,CDMA network locked Phones cannot be Unlocked from the Mobile Phone.
2helpful
Sim card error
What is your Phone Brand and it's Model?
Make sure that your phone has been unlocked....If the Phone Locked means if you insert Other Network Sim card means it says invalid Sim or Sim card error...So find out the Network and country locked now,all network locked Phones cannot be unlocked ,Some Network locked Phones can be Unlocked.It depend on the brand of the Mobile also,you can unlock it using the Unlock code,You can get the Unlock code from the Theunlockarena.com
and Unlock it,after Unlocked the Phone use any GSM Network Sim card,You cannot use the CDMA Network Sim Card in the Unlocked Phone,Only GSM Network locked Phones can be Unlocked...
Jul 04, 2011 • Cell Phones
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
15helpful
2answers
How do you unlock camera card it says card locked
Hi. Remove the card. On the side of the card is a small sliding lock. That's it. J.
Jul 12, 2010 • HP Cameras
Unlock memory card
There is a little 'lock' switch on the side on the card with a lock symbol. Slide the switch to the unlocked position to unlock your card!
Aug 06, 2008 • Cell Phones
18helpful
3answers
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
