Question about Nintendo DS Lite
Is it easy to calibrate a ds lite - Nintendo DS Lite
Posted by sweetpea_101 on
Ran Kedar
  • 977 Answers
Hi!
It's actually quite easy...
  1. Turn the DS on without a DS card inserted (or with Auto mode turned off).
  2. Touch the DS icon in the bottom middle of the screen.
  3. Press the far right yellow icon.You will then be taken to the calibrate screen.
  4. Touch the small red squares on the screen as they appear.
  5. Press Confirm amd exit menu.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Posted on Feb 07, 2011
My Nintendo DS Lite will only power on in GBA mode if there is a game in the slot but will not with a ds game it wont even turn on to pictochat menu could it be a fuse issue or maybe my lower screen is...
make sure there is no games in the slot, then see if you can get around using the directional buttons and the a button. if you can get to the settings menu, go to the calibrate screen option. if you cannot calibrate the screen, (if the target moves but you cannot finish the calibration) then you probably have a bad screen. here is a website that can sell you ds lite parts. they are not cheap, so buy what you need, and only what you need.
http://www.nintendorepairs.com/parts/index.html
Jan 10, 2010 | Nintendo DS Lite Console
Calibrate ds lite
If you would like to calibrate your screen...
Turn the DS on without a DS card inserted (or with auto mode turned off).
Then touch the DS icon in the bottom middle of the screen.
Press the far right yellow icon, with a crosshair in it.
Press confirm, exit menu.
Jan 06, 2010 | Nintendo DS Lite Console
Screen calibration
u may have to change the screen but iam not to sure where about they can be purchased but its a risk it might damage the ds. u may have to buy a new ds
Dec 26, 2009 | Nintendo DS Lite Console
Most of my ds lite touch screen is not responding
try getting to the calibration menu with the buttons and calibrate if u can if not send it in to nintendo for repairs
Sep 21, 2009 | Nintendo DS Lite Console
Stylus
Its not the styles it the ds
May 22, 2009 | Nerf Stylus Twin Pack for Nintendo DS...
Ds lite touch screen
Re-adjust your calibration settings in yur ds that should fix it.
Feb 03, 2008 | Nintendo DS Lite Console
TOUCH SREEN NINTENDO DS LITE
aparently fitting a new touchscreen works, i have just ordered one from ebay, cost me a tenner
Dec 31, 2007 | Nintendo DS Lite Console
DS Lite Touch Screen does not respond to touch
on the top right hand side of the screen just under the front there are four or five contact pads this is where the touch screen get the info from the touch screen to the ds itself if you have taken the ds apart maybe the pads are slightly out of line this can be fixed by applying light pressure to the pads to make them stick down and get a proper contact
Oct 08, 2007 | Nintendo DS Lite Console
Bottom screen
Sounds like the screen is broken. It may be fixable, but you're likely better off buying a new DS.
Sep 07, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Logo
50 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
