Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door only opens up about 2" and stops.
Don Maggard
    President:
  • 3,197 Answers
Check for a broken door spring and remove the cover from the motor unit and check for a stripped drive gear. The gear is white nylon and it will be obvious if it is bad.
Posted on Feb 07, 2011
How do you stop the door leaving a foot open at the bottom?
To stop the door in a partially open position, the button on the wall switch or remote should be pulsed when the door is opening from the fully closed position.
Jul 12, 2014 | liftmaster Garage Door 1/2 Hp
We just replaced the "trolley" component of the opener, now when we open the garage door it opens about a foot, then stops like its hung on something... it will go back down. If i help it pass the hun
Check your manual and re-program the up/stop and down/stop position. Also make sure the new trolly is in it's proper position.(in the closed position) Hope this helps
Oct 02, 2012 | Chamberlain 3/4-HP Power Drive Chain Drive...
Garage Door Opener Keypad I have an older Sears CRAFTSMAN Garage door opener and am trying to find a Keypad (that is afixed to the outside of the garage). that can operate the door. I have a remote (2...
Call around to the Chamberlain dealers in the yellow pages. They might have one in stock. The part number is 66LM. They are expensive though. $55.00. You might consider replacing that old opener you have.
Jan 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have 3 Sears 1/2 horse garage door operators. One has a "red," one has a "green" and one has the "purple" set button. The purple one is the only one that I can use the...
You have 3 openers that are completely different when it comes to technology. A billion code, a security + and the opener with the purple button is on a different radio frequency. There is no way to open all 3 doors with a keypad.
Jan 03, 2011 | Sears Craftsman LiftMaster Chamberlain...
When I try to put the garage door down, it will travel for 1-2 seconds. then it will stop, the unit will make 10 or so "clicking" noises that sound like a car blinker, and it doesn't close.
Check the sensors in the doorway. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close entirely
door will not close all the way. will go partway down then reverse itself.
Oct 20, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
