SOURCE: maytag mbd5100awww spray arms not working
ur swing arm retainer and bearing are worn. its about $20 FIX for parts and the job is easy.
SOURCE: spray arm for Maytag dishwasher
altough you cant seperate them loosing hte little to nut will allow you to remve and alittle patience you'll be able to swish them around and through larger center mounting hole. the only other option is to replace the arm p/n 99002678 just under 20 bucks
SOURCE: dishwasher - no spray arm action
I also had this problem and it turned out to be a small piece of a drinking glass that had made it all the way to the chopper and wedged between the blade and the housing. I was able to do all of the work from inside the dishwasher without disconnecting anything.
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
In you case check the heating element first...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things...
Bought new spray arms online and installed them in minutes...now the thing works like new...
However I have also found that if the heating element goes bad then that also can mess things up bad...
So I would buy new spray arms, and also check out the heating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
I
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
dishwashers...
Element not Working
Dishwasher
Maintenance
Dishwasher
Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
