Question about Microsoft Xbox 360 Console
My power adapotor goes on but no power to xbox
Posted by jamesbarns on
Eddie Chen
  • 661 Answers
Yank your faceplate off and look where the power button should be; there will be a small gold button in a small recess in the center of the plate under the faceplate. poke that with a pencil or something, just be careful. If it doesn't turn on, then you'll have to call microsoft; something inside is broken.
Posted on Feb 07, 2011
Alex Edoh
  • 943 Answers
This is usually caused by either a short circuit in the power box or a faulty cable, the cable in question is the second joint of the cable which is connected to the power box and then connected to the console.
There are only a few checks that can be done at home after which if there is still problem, you may just have to see a repairer or replace it with a new one.
These checks include that you do the following
1. Make sure that this second joint is well connected to both the power box and the console.
2. Make sure that there is not broken or bent pin in the power box outlet which leads to the connection for the second joint.
3. Make sure that there is no form of dust particles or related elements that can prevent the flow of current into the console
After doing this, you can go ahead to borrow a second joint of the power pack from a mate and see if his would work on your own and if yours would work on his own. If it doesn't then you can be sure that you have a faulty power pack.
If you want to continue, you can see a repairer or purchase a new one.
Hope this was helpful?
Xbox will not power up
Hi, A totally died xbox is telling you there is no power feeds to the device Please check your power supply line. Use VOLTMETER to get the voltage output of your power supply. If there is , please trace the power goes to circuit board of Xbox. There should something problem and need to fix there.
Regards, Jay
Dec 25, 2010 | Microsoft Xbox 360 Console
Hi, I have an xbox 360 and when I turn it on it goes to the splash screen then goes no further. The animation doesn't freeze. There are no lights on the xbox and the controller lights flash, when I try to...
there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console.
Click here to download repair guide
Dec 14, 2010 | Microsoft Xbox 360 Console
No power to console. The power pack is good but the unit does not turn on
Maybe a connection problem where the power pack goes inside the xbox. If you have a friend close with one, try their power pack on your xbox and see if it turns on. If it does, the power pack you have is faulty. If it does not turn on, then you know there is something internal in your xbox causing this.
May 15, 2010 | Microsoft Xbox 360 Console
Wireless Adaptor for the 1500?
Yes. model number is WIS09ABGNX/XAA. YOU CAN CONTACT SAMSUNG AND PURCHASE IT.
Mar 25, 2010 | Samsung BD-P1500 Blu-Ray Player
360 won't power up power supply good is there a fuse
They dont have a fuse in side them , it could be dry solder joints on the main pcb where the power plug goes into the xbox, make sure you try your power supply on another xbox as well as your xbox on another power supply. Also check the led on the power supply is green when its running, if the light is orange or red(whislt running, the light will be orange when in standby) .If your led on the power supply is red , you have a faulty power supply. Good Luck.
Sep 24, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont turn on
try a new power cord to see if thats the problem, then buy a new one.
May 30, 2009 | Microsoft Xbox 360 Arcade
Xbox help
GET NEW XBOX! POOR MAN
Jan 12, 2008 | Microsoft Xbox 360 Console
Xbox360
This means you have insuffiecient power for your XBOX 360 to work. You need a stronger power source
Dec 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
