Question about BenQ T701 TFT 17" LCD Monitor
Power light is on but the monitor does not start. I must say that I pulled the plugs on a monitor that works and then I plugged in the monitor defect but without results. What would be the problem ... is Benq T701 Monitor ... Thank you very much
Posted by iuriboy2000 on
drunknmonkey
    Novelist:
  • 136 Answers
P { margin-bottom: 0.21cm; }a:link { }
Sounds like some bad electrolytic capacitors, it's easily fixed. I highly recommend reading the links at the bottom, it'll give a you a better insight into the problem and solution.
You have 2 or 3 options:
1. If it's under warranty then you could send it back to be fixed, problem is they will likely use the same rubbish brand of capacitors again, but anything else will void the warranty.
2. Pay a tv repairman or similar to fix it for you. They may still use substandard capacitors, so specify what brand you want them to use, this will probably mean waiting longer and possibly paying a little more. This way you know the job should be done right.
3. You could replace them yourself if you're comfortable with a soldering iron, or know someone who is. The capacitors themselves are quite cheap and easy to replace.
Go for the best ones you can get for the job and try to buy from reputable companies, the links below will help you chose but you can't go wrong with Rubycons. Every capacitor manufacturer has several ranges, each having different properties which make some more suitable than others
Always match the values on the original capacitors. You can actually use slightly different values for the capacitance and voltage (uf and v) but never use ones below what the originals are rated at.
The links below will explain this further.
They should look something like this:
As you should be able to see, the one on the left is bulging. The blue stripe with the arrow tells you that the lead on that side is the negative, the positive lead should also be longer than the negative one(only on a new cap, old ones will have been trimmed).
Tools needed
1. Soldering iron. - preferably with a stand with a sponge in.
2. Solder - there's different types so make sure it's suitable for electronics
3. Phillips screwdriver
4. Flat head screwdriver
5. Wirecutters
6. De-soldering wick, or pump. - definitely recommended but not really essential.
If you haven't already got the tools then it's a good investment, as bad caps cause a lot of faults in all kinds of electronics.
Instructions
1. Unplug monitor and open case.
2. Identify power board, it should have a lot of electrolytic caps on there and obviously should be connected to where the power lead is attached.
3. Identify the bad caps, they should be bulging and/or leaking, although not always. Note down the three values for each cap (eg 220uf, 16v, 105c) and their approximate dimensions, and get new ones, preferably Rubicon or Panasonic, the link below will help you chose some good ones. If in doubt you could remove them and take them to the shop, but you'll have to remember where each one goes and which way round it was (take pics).
4. Very carefully heat up the contact on one side with the soldering iron, and rock the cap the other way, then do the other side, keep doing this until the cap comes out, if you have a de-soldering wick/pump use it to remove the solder and it should just pop out easily.
4. Replace with new cap, making sure that you observe the polarity and make sure it's securely seated and soldered in. Make sure the solder is neat, tidy and doesn't contact anything else. If there's any solder left in the holes then you'll have to heat it up or remove it before you can get the new cap's leads through. Once done properly trim the leads off so they won't cause any problems.
5. Replace casing and test. If it doesn't work then you'll have been a bit messy with the solder, tidy it up and try it again.
Here's a few links to help you:
Bad caps faq - should have pretty much everything you need to know.
http://www.badcaps.net/forum/showthread.php?t=425
Hints on soldering.
http://www.kpsec.freeuk.com/solder.htm
Posted on Feb 07, 2011
My computer monitor wont start up
try pulling out the power plug to the monitor and then plug back in and turn on monitor.
I am assuming you plugged the DVI cable back in to the correct port on the monitor and Mac Pro.
May 03, 2016 | Computers & Internet
KDS k 72mb
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 08, 2014 | KDS Computers & Internet
My compaq fs7600 won't start up I've held the start button and it came in before but it is not working now
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 16, 2014 | Computers & Internet
Viewsonic VX2835wm. With on/ off button sometime does not respond. Have to pull plug to "reset" it.\r\n After start working keeps working as long as I don't shut it off. Instead of switching...
Yes, it can be unstable DC voltage problem due to high AC ripple because of the bad DC filter caps, you need to inspect the power supply section for any caps with bulging top or bottom seals on the cap. Bad cap can look normal but can have high ESR.
The VX series are known to use alot of bad caps as you can see in my pictures here: http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/
Alos look at the caps in the main board also.
Please post back what you find.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 09, 2011 | ViewSonic VX2835WM 28 inch LCD Monitor
Hi! Ive bought an Asus LS246h today and it won't start. Ive checked all cables and Ive got power on the power plug. None of the lights at the monitor are working! Is my monitor defect?
Hello there,
It looks like you have a faulty monitor. Make sure the power is plugged in at the computer and a working all socket. Make sure that the Box on the power cord is connected properly. Make sure that the connections to the computer and secure and that the computer is turned on. If none of these things fix the monitor, I recommend returning it and getting it replace.
I hope this has helped! Thumbs up are much appreciated.
May 07, 2011 | ASUS LS246H Monitor
I unplugged my computer and turned off the monitor to save power since we were not using. Now with the computer plugged in, when I turn monitor on the green light just blinks.
Make sure the data plug is in correctly. Turn the computer on. No you can try using the power button on the monitor to power it off and on. Or you may need to pull the power for the monitor out of the plug and then put it back in.
The blinking light means the monitor is in sleep mode. They need activity on the data or signal cable before they wake up. Unfortunately sometimes they get stuck and you have to reboot them to wake them up. I have seen a few where they had failed and would not come out of sleep mode but that is pretty rare. Usually you just have to sweet talk it and threaten it a bit and pull it plug a few times and all of a sudden it will start up,
Feb 01, 2011 | Hanns.G Corporation HW173D Monitor
Wont start up
Check physical connections first, check monitor cable if securely plugged in and then check power light of monitor. If power light on monitor is amber or yellow it means that monitor is not getting a signal from cpu/ tower. Try to do a power drain on the computer, remove power cable at the back of the computer and then press and hold the power button for 10 secs, after that plug in power cable again and restart the computer.Check if there is any connection if not then try to use another monitor, a known good one. If you get a video from another monitor it means monitor is already defective.
May 15, 2010 | HP Pavilion a1610n PC Desktop
My computer will not start
This problem can be caused by various reasons check the power cord ,wall socket if your hear any beep sound then the rams could be defective the internal power supply may be defective the mother board can be defective.
Feb 09, 2010 | Computers & Internet
How to know if the monitor is totally dead?
Generally, if the power light (LED) doesn't come on and there is no screen display with or without input signal, it's dead. Probably a failed power supply.
Aug 29, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
DCLCD 19" flatscreen won't turn on correctly
Same problem here, but after using the plugging/unplugging method it eventually stopped all together. So, I took it to a local monitor repair shop (AM Stereo, Seattle). The problem is a power supply issue where the capasitors go bad. They fixed the monitor by replacing the capacitors for $70. In there experience, all monitors, regardless of brand, tend to use the same cheap capacitors which fail. He replaced them with better quality capacitors which may make this monitor better than it ever was. I'm back in business with a great monitor!
Oct 31, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
BenQ T701 TFT 17" LCD Monitor Logo
112 people viewed this question
Top BenQ Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Paul Bade
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
