Question about HP Photosmart C7280 Laser Printer
My printer has a "Pump Motor Stalled " message. It
Posted by lidya23 on
Black Diamond
    New Friend:
  • 16 Answers
Hello. First of all you have to "Reset the printer" to factory default. To do this, you have to press and hold # & 6 at the same after you push the "Power" button. Hold the # & 6 keys till to see the power led blinking. The printer will reset to defaults and give it 1-2 minutes to warm up and prepare its software. After this check if your printer is working properly. If not, open the access door and check if there is a paper jam inside(left or right) behind the cartridges. If not again, buy a Blower( a machine that blows air with a lot of power) and use it to clean the interior of your printer. After this buy some lubricant and insert it with attension where you see cogwheels. After all those things your printer will work without any problem.
Posted on Apr 09, 2011
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
Im trying to print with our Canon PIXMA IP3000 printer but it doesn't allow printing with a message box appearing "printer is offline" but the printer is perfectly fine and plugged in. Then I chec
check to make sure you have it set on the right printer by find printer... if that is okay check your ink levels and make sure they are in properly... you might also want to try restarting the printer and if none of those work you will have to try and uninstall the printer and then reinstall it....
Dec 21, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
I have an epson stylus TX110 and it was printing fine today, but then as is sent a job from adobe it prepared to print (made usual noises) but then didnt take any paper and just went quiet. I've tried...
Try purging your temp files. If it's a usb connection try a different usb port. Since it can print from scan and do a test nozzle print then it's not getting data from the pc to the printer. If a different port doesn't work either, and if purging your temp files doesn't work try it on a different computer if possible. You may need to reinstall the driver for it.
oh and make sure you don't end up with one of those 'oh duh' moments :) ... check both ends of the cable to make sure it didn't become loose or unplugged :)
Jun 05, 2011 | Epson Stylus Photo R1900 InkJet Printer
I was able to scan to my computer four pictures without any problems. When I tried the fifth, I get a "scan request failed" repeatedly. Nothing changed between the computer and the printer. ...
What is the status of the WiFi light on your printer? Try to check if your printer is still connected to your wireless network by printing the wireless network settings. How to Print the Network Settings Page on the X3500 and X4500 Series Inkjets; a Brief Explanation of its Values. Check the SSID and the IP address of the printer and see if it's the same as your network.
You can also try to relaunch the Lexmark Wireless Setup utility to connect to the printer again.
May 28, 2011 | Lexmark X4530 InkJet Printer
Pump motor stalled
Hi victor_orell,
The Pump stalled error it is often caused by the ink system has failed. To correct this error please follow the steps below.
1. Power drain. Please unplug the power cord at the back of the printer. Press and hold down the power key for 30 seconds then release the key and plug the power cord back in.
--> if this doesn't work please proceed to the next step.
2. Partial Reset. Please unplug the power cord at the back of the printer.Press and hold the # and 3 keys together and while holding them plug the power cord back in. Check if the problem is resolved.
If Not
3. Semifull reset: Unplug the power cord from the back of the printer again. Press and hold the # and 6 keys together and while holding them plug the power cord back in.
4. If you're still encountering the same error, please remove all the print cartridges (with the system powered up). Clean the copper contacts with the help of a lint free cloth then reinstalled them. Allow the printer to go through its normal sequence then go to the Setup, select tools, then clean print head.
Hope it helps.
Thank you for using FixYa.
May 02, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hi! I use Toshiba eStudio as photocopier & printer, but I didn't know why the message :"REMAINING 60 DAYS .." appear on LCD. How I return all as default setting. Tks!
on the toshiba machines you can activate a trial period for printing and scanning without the print/scan dongle this is what you are seeing
Mar 15, 2011 | Toshiba E-STUDIO 720 Copier
HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Mar 04, 2011 | HP Photosmart C7280 Printer
Error Message: Pump Motor Stalled. Please advise
Try partial reset and semi full reset of the printer, this is error message is a hardware error, if the issue is still not resolved contact HP, they would replace the printer if it is under warranty.
Sep 28, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Pump motor stalled
Try this I have had machine similar apart On the left hand side (Facing the printer) behind side cover sits a micro pump for the ink. Pull cover and check that belt is OK from gear to micro pump. You should be able to just turn back and forth- not too much, the large pulley on the pump. There will be some friction here..... I think you can turn on machine OK with this cover off and see if pulley is turning
Apr 24, 2009 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart C7280 Laser Printer Logo
701 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
