Question about Kenmore Vacuums
While using the power mate rug part I caught a small rug and the vacuum would no longer pick-up .
Posted by jazziz on
Chris Nomland
    New Friend:
  • 124 Answers
Check to see if there is a reset button on the head. This protects the machine for times like you described. When something jms up the reset button will turn ofdf th machine. Simply push the reset. Hope this helps, Chris
Posted on Feb 07, 2011
rugbadger
    New Friend:
    Problem Solver:
  • 11 Answers
No revoloving brush type vacuum should ever be used on a loose rug as the fringes and edges will get caught in the brush. Not only can this damage the vacuum, but the rug will be damaged. We recommend a suction only type of nozzle with no brushs for all loose rugs.
Stephen "Dusty" Roberts
Certified Master Rug cleaner
www.luvarug.com
Posted on Feb 13, 2011
Brushes not turning
Unplug it from the power source. Then remove the cover and see if the belt is broken or derailed from the motor.
Sep 02, 2014 | Vacuums
I transported my newly given to me by my dad tristar from Fl to LA and I can't get the reset button to start the power. The vacuum comes on, but the rug attachment is not spinning I can't get
If the rug attachment is not spinning, it is likely the drive belt has come off. Also, the entire intake area probably needs to be cleaned.
If the vacuum cleaner starts, the reset button has nothing to do with why the attachment doesn't spin.
Sep 12, 2012 | Tristar Vacuums
Power mate rug beater no longer spins
Two possible problems: 1. Reset the fuse by pushing on the red dot.; 2. replace the belt.
Jul 23, 2011 | Kenmore Vacuums
My sd40025 dirt devil ..it is not a upright. it is the follow along, bagless vacuum. has wonderful pick-up but the brush stopped spinning when i was vacumming my rug..i love this vacumm but it is only the...
That's because you got something caught in the brush and it tore the belt (likely) or slipped off the drive portion of the motor (unlikely).
If you look at the bottom where the brush is, there are a bunch of screws to remove the bottom cover usually and can access the belt and motor to run the brush. \
belts are usually 5 to 10.00 get a pack of 2 if possible and don't do heavy rugs or get material caught in the brush lest it will happen again.. typically you can find vacuums in the trash and remove their belts, usually is only 2 or 3 types of belts so get one for free perhaps from trash.
Nov 23, 2017 | Dirt Devil SD40020 Bagged Canister Vacuum
A throw rug got caught in the rolling pin of vaccuum. Rolling pin no longer works.
Hello. more likely than not, the small belt that drives the roller has either dislodged or broken. Unless you have a dyson, you can replace that belt for about 5 dollars. The dyson, however has encased the belt in a plastic assembly and the entire assembly must be replaced for about 80 dollars. J.
Jul 02, 2010 | Vacuums
Beater bar stopped working
hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
String caught in end of rug brush
This pdf file should help you - there are instructions in it for removal of the roller.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0412323.pdf
Rate if this helps :)
Feb 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
How can i keep the belt onmy sharp vacuum
If you have a rug that has tassles or open bits of "carpet tassles," this will injur ANY upright vacuum cleaner. Best way to vacuum a rug is to use a hose with a suction only floor head or small tool on the end.
Jan 29, 2009 | Sharp Twin Energy EC-T2630 Bagged Upright...
Vacuums Logo
178 people viewed this question
Top Kenmore Vacuums Experts
Marvin
Marvin
jdthefixer
Mike
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
