Question about NetGear WNR1000 Router
I am trying to connect my Ipad to my wireless router (Wi Fi) and the Ipad is telling me I have enter the incorrect password.. I know that I am entering the correct password.. Please help me.
Posted by bonniemolone on
Rofel Lantican
  • 2,632 Answers
Welcome to Fixya. If you iPad is not accepting you password you can check the password or Network Key on your router. To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Don't forget to say thanks. Thanks for using Fixya
Posted on Feb 07, 2011
HOW do i use wps on my ipad with WNR2000
Depending on your browser, download or display the pdf of the WNR2000 manual ( http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf ). The manual might also be found on the CD that came with the router.Follow instructions Chapter 2 Page 7 to enable/setup WPA2-PSK (AES).Make sure you SAVE/APPLY the settings before proceeding. Follow instructions Chapter 2 Page 17 to Disable Router's PIN. When you do, make sure you leave the box checked to "Keep Existing Wireless Settings".Make sure you SAVE/APPLY the settings before proceeding.Here's a work-around ff the above doesn't fix the issue for you. Sorry I don't have iPad-specific instructions, but I don't have access to an iPad/iPhone at the moment. I've done the following on iPads, iPhones, Android phones and tablets, Windows phones and PC's - it works on virtually all Wi-Fi-capable devices..:
Instead of letting your iPad find the network and trying to connect with the password, try manually creating a new Wi-Fi network connection by typing in your Wi-Fi network name (SSID), selecting WPA2 (AES) encryption and entering the Wi-Fi password your configured in STEP 2 above.Please note: You'll have to forget the Wi-Fi network in your iPad's settings if you keep your Wi-Fi network name (SSID) the same as it is currently.
May 25, 2016 | NetGear WNR2000 Wireless Router
I have purchased the iPad Air 2 and I have the Net Gear A6300 plus
The process is fairly simple.
  • Choose the setting app on your iPad (the one with the gear icon).
  • Choose Wi-Fi
  • Make sure the Wi-Fi setting slider is green (on).
  • click on your network name under "CHOOSE A NETWORK"
  • enter your password (if necessary) for that network
Your network information will be saved and you will never have to enter that information again.
If you don't see your network, check to see if your router is working, and move closer to your wireless router to complete the settings
If you don't receive a wifi signal where you use your iPad, you might reposition your router, or move your iPad closer, or get a wifi repeater (like an Apple Airport Express) to extend your signal.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
Mar 27, 2015 | Apple - iPad Air 2 Wi-Fi 64GB
My I-Pad will no longer connect to WI-FI. Any suggestions?
Take to "Genius Bar" in Apple store; they will Dx for free; only charge if repair is necessary!
Sep 27, 2014 | Apple Ipad I-pad
How reset ipad passcode
  1. Start the iPad
  2. Tap on the Settings app
  3. Tap on the Wi-Fi category
  4. Choose a Network
  5. Once you Tap on a network name, it will try to connect to it. If the network is using wireless encryption, though, you will be presented with a screen asking you to enter the wireless encryption password.
How to connect an iPad to Wireless or Wi Fi network
Aug 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I have to enter my password several times to get my kindle to log on. I always have to log on..the signal seems to be weak adjacent to the router. authentication failed is a normal response on my kindle....
your kindle device should be able to connect the network automatically , if this is not happening try adding the network manually.
1.First, make sure you are within range of the network you want to add, and that you know the network name and password (if required).
2.From the Home screen, tap Menu and select Settings.
3.Select Wi-Fi Networks to display a list of detected Wi-Fi networks.
4.Tap Join to enter network details.
5.Use the onscreen keyboard to enter the name of the Wi-Fi network that you want to add.
6.Once the Network Name has been entered, tap the Password box and enter Wi-Fi password / Network Key using the onscreen keyboard (if required).
Tip: Tap the 123 key to enter numbers or symbols. Tap the ABC key to return to the regular keyboard. Tap the Shift key (up arrow) to enter uppercase characters. Your password may include non-English letters (accents, umlauts etc.). To view accent options, press and hold a letter down, and accent options appear.
7.Tap Connect
Does all your wireless devices have weak signal issues?If so , Then problem may be with the wireless router.Try changing the wireless channel on the router by logging into the router interface page.
Authentication failed is the message u ll normally get when u enter the password incorrectly.
Aug 07, 2013 | Belkin (F5D7230-4) Router (587009)
Trying to connect my ipad 2 to wi fi via belkin surf n 300 wireless router put password in and message camesup "unable to join the network "Belkin.361B"
Before you start :
Make Sure the Wireless Switch on your Computer is turned Off (If you are using a laptop to connect to the router )
Make sure that the Light on the Router is Solid Green
Step 1 : connect a computer to the router (Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 18, 2011 | Belkin Surf N300 Wireless N Router
I am trying to connect my ipad to my wireless network and have forgotten my password. HELP. To connect to wi-fi I need a password and can not remember the password as this router was set up years ago
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click on wireless then wireless security Enable WEP then enter new password save settings and restart router .Then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Nov 18, 2010 | Belkin (F5D8231-4) Wireless Router...
Connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Jun 25, 2009 | NetGear DG834G Router
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
NetGear WNR1000 Router Logo
667 people viewed this question
Top NetGear Computers & Internet Experts
Mike
Jeffrey Groves
Jeffrey Groves
efs_perpends
efs_perpends
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
