SOURCE: electronic ignition
Alien, one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad. Catriver...post back.
SOURCE: PILOT CLICKING
Dawnie, under each burner control there is a valve and a switch. One of your switches has either become wet or shorted out. This is why it's clicking. Sometimes grease gets in them and causes this problem. The part number for the switch is 7403p367-60. You can look it up on the net to see what Im talking about. Not a hard fix. Catriver..post back.
SOURCE: 1 burner wont stop clicking on miele cooktop km 344
usually due to the ignition unit being faulty. being miele, the part will be pricey. another solution is to take out the ignition unit and take it into a local electrical repair outfit and see if it can be matched up with one from a different make. to check if this is the problem, interchange two electrode leads on the ignition unit and see if fault changers to another burner. you sometimes find that there is a spare ignition outlet on the ignition unit and this can be used as an alternative
SOURCE: kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
SOURCE: Viking pro 6 burner cooktop igniter won't stop
Do not attempt if your stovetop is hot, you will get burned!!
This is an easy fix, the problem is your burners aren't lined up properly. Remove the iron grates (what your pots rest on) and the burner cap (the round black top on the burner) and finally the burner base (the round golden colored piece resting on the stainless stovetop). If you flip the base over you will see that it is keyed, meaning there is a grove that fits the indentation on the stove top. When you replace the base make sure to line the grove up with the indentation. If it's not flush with the stove top, slowly twist the round burner base until it falls into place. That's it!
