Question about Danby Microwave Ovens
I have a Danby DMW946SS Microwave oven. Today morning, I found that some of the keys( Start/Stop, some of the numbers) didn't work. I unpluged it for more than 5 minutes but it's not working. Please advice me.
Posted by ah_razavi on
5 Related Answers
SOURCE: Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Posted on Sep 24, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: emerson mwg9111sl microwave oven won't turn off unless unplugged
I would suspect a bad door switch or mount or a problem on the control panel.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020.
Get help locating a local authorized servicer at 1-800-695-0098.
Posted on Nov 24, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: faulty microwave function on the SHARP R-957 model (900watt)
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Posted on Dec 13, 2008
Anonymous
SOURCE: how much is the cost for a new Household Microwave Oven (Danby)
To replace your model of Danby.... costs around $90 bucks. To fix ur Danby if its broken.... $65/hr service charge (minimum) plus parts.... We are in the disposable society, sad... but its cheaper to throw ur microwave away unless u know the basics to fix it ... like a fuse replacement. Otherwise,.. just go out and buy a new one.
Posted on Apr 04, 2009
Anonymous
  • 68 Answers
SOURCE: Danby DMW745SS Microwave, no power.
Try to cheeck the fuse.
Posted on May 18, 2009
Microwave wont shut off
there is just a malfuction in the circute board go and get it fixed
Apr 01, 2015 | Danby Microwave Ovens
My microwave was shouting with the numbers 2222 for the past one weeek and i used to always unplug it unless i use it.. from yesterday it was ok with and this morning when i used, it suddenly went off n...
Microwave ovens operate at high voltages and powerful radio wave energies.
Any questions in the operation of one indicates for safety toss it into the trash and buy a new one.
Sep 21, 2017 | Danby DMW1153 Microwave Oven
My danby microwave beeps all the time for no reason
Did you find a solution?
I've got the same ******* problem with mine!
Oct 01, 2009 | Danby DMW773 Microwave Oven
Chefmate microwave P70D20AL-D4 beeping
After calling many numbers, I was put in contact with the manufacturer, Galanz Microwave, and was told that that beeping is due to a burned out part in the keypad that is not servicable. I, too, have this annoying model!
Jul 19, 2009 | Danby DMW1153 Microwave Oven
My microwave buttons dont work on my danby microwave, after a few hours it started beeping and asking for a code. what is the code
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If it still isn't working I would contact Danby Customer Service US / Canada.
Jan 08, 2009 | Danby DMW1146SS Microwave Oven
Buttons dont work on danby microwave
If it still isn;t working I would contact Danby Customer Service US / Canada.
Danby DMW753W ; machine starts without any command
The membrane of the touch control is shorted and must be replaced.
Mar 27, 2017 | Danby DMW773 Microwave Oven
Danby turntable keeps spinning
2 THINGS COME TO MIND--A BAD ELECTRONIC CONTROL PANEL (BEHIND THE KEYBOARD) USUALLY FROM A POWER SURGE,,,,OR A BAD SOOR SWITCH--THIS REPAIR WOULD NEED A TECH--TUNICA
Oct 30, 2008 | Danby DMW119 Microwave Oven
BEEPING EVERY 30 SECONDS
Your oven has a 24 month parts and labor warranty.
I would contact Danby:
Consumer Help Line
1-800-26-DANBY
(1-800-263-2629)
Hours of Operation:
Monday -- Thursday 8:30am - 5:00pm EST
Friday 8:30am - 4:00pm EST
Or you may e-mail Danby Service at [email protected]
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Danby DMW119 Microwave Oven
Danby microwave m # 1153
danby dmw11536 my microwave oven start beeping all the time. i can start it if ipush the cancel button, ordinarely once but sometimes it won't start unless you unplug it. also disylay shows 1:00 but keep time of cooking anyway. after it returns to beeping all the time, sometime you have to leave it unplugged for a couple of hours. danby dmw11536
Aug 27, 2007 | Microwave Ovens
Microwave Ovens Logo
97 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
john h
Ruth summersides
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
