SOURCE: ibm thinkpad t42 switch for wireless network
The T42 has a bulit-in wireless network adapter and a LAN network card. T42s most likely have an Intel wireless card or less likely a Cisco wireless card.
Your wireless network adapter may have been disabled in the BIOS
and/or
The drivers for the wireless network controller has not been installed.
To check the network adapter go to the Control Panel, Click on System, click on Hardware Tab then Device Manager. Then scroll down and click on Network adapters. If you don't see your network controller or you see a yellow ? against Other devices for the Network controller. Then either it has been disabled and/or the driver was not installed.
To get the driver for the network controller you need to dowload it from the IBM/Lenovo WEB site their support/download page from a computer that has Internet access. Make sure you select your laptop model and the driver for your Windows version.
Install the driver and you then need to configure the wireless adapter to suit your wireless router settings before you can access the Internet.
SOURCE: where is the wireless switch for ibm t42 laptop i
There is no dedicated one key/button for wireless for IBM Thinkpad T42. If "Fn" + "F5" keys for the on-screen function that activate/de-activate the wireless not working, you can access it by IBM utility software: Start.All Programs.Access IBM. IBM Access Connections. You can use the software to disable/enable the Fn+F5.
SOURCE: Where is the wireless switch located on the IBM
Unlike the newer laptops, the T42 doesn't have it's own wireless switch. So in order to get the wireless working, you need to also make sure that the Power Management driver and the Hotkey driver are installed as well.
Load the drivers in this order:
1) Power Management driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4GXPEG
2) Hotkey driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-68000
3) Wireless Driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70504
After downloading it, you must go into C>Drivers>Win>Wlanint and run the setup file from there.
4) Access Connections (Optional) - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4ZLNJB
SOURCE: My wireless was working on
For most IBM ThinkPads, the shortcut key to activate wireless is Fn+F5. I am not so sure about this model, but you can try. If this doesn't help, check the Device Manager and make sure it's shown on the devices lists. By default wireless is activated once the driver is installed on almost all IBM ThinkPads. You problem could be driver corrupted or missing. The best resolution is reinstalling the driver so that it'll not fail. If the problem persists, then it could also be your wireless card failure. You better check it twice.
Good luck.
Thanks for using FixYa.
SOURCE: how do i locate the
The T42 ThinkPad does not have a wireless switch. When the wireless driver is installed then the wireless card is automatically switched on.
To download the wireless driver - follow these instructions.
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver.
When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive.
Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP or Vista devicedrivers for your model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
