Question about Toyotomi TIN/TIG-329D Air Conditioner
I can't find how to raise heating temperature from the remote control.thanks
Posted by tbermperidis on
summerdomez
    New Friend:
What is mean e8
Posted on Dec 01, 2013
The fireplace won't turn on when it gets below the set point on the remote. The flame icon is on and I think it's keeping the fireplace from coming on.
That's because you have reached your desired room temperature as set on the remote. Raise the set point to a higher value.
Dec 14, 2017 | Heating & Cooling
How do i put it on warm
on the remote control press mode button until u see the icon of the sun. then raise your temperature setting to the desired degree. there is a 3min delay from going from a/c, dehumidify to heat. temp will rise in the indoor unit. fan speed will be slow until it hits 90* across the evap coil then it will start ramping up in speed as temp rises.
Mar 12, 2014 | Samsung AS18A6RB Air Conditioner
Temperature control
If you go to this website they can assist you with getting technical assistance on diagnosing your issue and getting a remote for you. Hope this helps. http://www.rick-horwath.com/Whalen_Windham_Combination_Electric_Fireplace_Heater_Manual.pdf
Dec 26, 2013 | Whalen Furniture Windham Fireplace TV...
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
I own a Rinai Integrity 2532. It heats the water for the in-floor heating. About once every other day on average, the controller switches the temperature reading from its setting (150 degrees) to 10 and...
Sorry to read about your problem, I hope this helps you out.
You have not said anything about error codes, Based on that. You may have a defective remote control, to replace the remote, would be the first step. it would be the lowest cost to you.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Rinnai Digital Remote Water Heater Control...
How do I turn it on? I press the "on" button and
The manual says:
http://www.coinwash.com/temp/rinnai.pdf
"For the name of the Authorized Distributor or Installer nearest you, please contact your local HVAC dealer or gas service technician, visit the Rinnai website (www.rinnai.us), call Rinnai at1-800-621-9419 or write to Rinnai, 103 International Drive, Peachtree City, Georgia 30269"
Manual says that the remote is for setting temperature.
When you turn on hot water spigot, tankless water heater will heat the water to the set point temperature.
If water heater is not set up to use remote, then tankless unit will heat to 140 degrees F.
"With the MCC-45-4US remote control installed the water temperature is adjustable from 96
to 180°F. The water temperature cannot be set to a temperature other than 140°F
without the use of the MCC-45-4US remote control unit. If you require a temperature
other than 140°F you must install the MCC-45-4US remote control unit."
"Error messages are displayed on the remote control units, simplifying service calls."
Page 9 of manual shows hot to set temperature using remote.
Water taps must be shut off to set temperature.
Circulating pump must be turned off.
"Simply press the H or C button until desired temperature is displayed"
"green in-use indicator will display"
If your unit is not working, the manual says to contact local plumber.
Fixya has specialists who will talk to you by phone about your problem for a fee.
Dec 18, 2010 | Rinnai Digital Remote Water Heater Control...
How do i raise the temperature from 120 degrees to 125 degrees
You need to use a remote control to raise the temperature from 120 to 125. The part number is N-7649M.
Sep 19, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
Need a new control panel for Maytag mey12f7e
Call this number, they can get you a remote, probably the easiest and cheapest route
800.935.0062
Jun 11, 2009 | Maytag MEY12F7E Air Conditioner
Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Nov 28, 2007 | GE Zoneline AZ55H09D Air Conditioner
Toyotomi TIN/TIG-329D Air Conditioner Logo
128 people viewed this question
Top Toyotomi Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Thomas Woodburn
Thomas Woodburn
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
