Question about Kenmore Washing Machines
Hello, I've got a 80 series Kenmore top loading washer. I recently had to replace its dogs due to agitation issues (problem fixed) but now not but 2 months later the "washer drum" (?) is hitting the inside wall during any spin cycle. I've redistributed the clothing and run it with only water (both large and small loads) and it continues - I have to hold down the lid switch and keep my hand on the top of the drum to keep it from hitting the wall. It leans towards the wall even when not in use - fixes are possible a new washer isn't. Can anyone still help regarding these old washers? Thanks
Posted by Mark1313 on
marka19
    President:
  • 1,430 Answers
This is likely the washer wear pads. They are inexpensive and fairly easy to replace. Here is a video that will walk you thru it Washer wear pad replacement Now before fully disassembling check the tub springs and counter weight spring. Sometimes they break or rust out. If they look good then move on to the wear pads.
Posted on Feb 07, 2011
Kenmore Series 80 washer. Agitates too slow
check the dogs in the agitator take off the cap it should rachett if it turns free replace the dogs in the agitator
Jul 12, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator: bottom moves, top does not
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
Replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Washing Machines
Kenmore series 80 washer: does not twist in the middle
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced.
Remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Part number is 80040
Let me know if you need more help.
Apr 01, 2009 | Kenmore Washing Machines
Agitator not working - how do you take it apart - Kenmore 80 Series washer
Pop the top off the agitator. There is a slot for a flat screwdriver on the top side.
Remove the 7/16 bolt.
Pull the agitator apart.
Replace the agitator dogs inside the top part.
Parts about $5.00.at any appliance parts store.
Mar 14, 2009 | Kenmore 23012 Top Load Washer
Kenmore series 80 model 1102983120 older top agitator gone
if just the dogs are gone you can replace them wim any agitaor dog kit. I usually use whatever kit was cheaper when i order abd put just the dogs on. never had a problem yet.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Top half of dual agitator stop working.
Most likely th agitatot dogs have worn out.. The part number is80040. They are located inside the agitator thy look like quotation marks. There is also a kit available which includes the dogs but more often it is just the dogs that are the problem. Good Luck.
Jan 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series
more than likely the dogs inside the agitator are bad
there are two different sets 1 set has 4 white ones part number is 285770 the 2 dog set whitch are red part number is 358692
replace these and it will fix your problem
Apr 11, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series
replace the dog set in the agaitator some have a 4 dog set part number 285770 and these are white some have a 2 dog set the part number is 358692 replacing these dogs will fixya
Apr 07, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
53 people viewed this question
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
Will Mishler
Will Mishler
